Guest WESTCORT Posted May 28, 2005 Share Posted May 28, 2005 ok so was putting the dizzy back in to the block along with the new rubber round seal thingy and it does NOT want to fit right in. its like the rubber ring is too big or something because it fits fine without the ring. I couldnt force it in with my strength or my hammer so i wanted to know if anyone else who has recently rebuilt their xflow had a similar problem with putting hte dizzy back in after replacing the seal? im guessing they must have given me one thats too big or sumthing, i have no clue Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 28, 2005 Share Posted May 28, 2005 uuumm seal dizzy thing ...i dont remember having to use one of those :S Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 28, 2005 Share Posted May 28, 2005 Thats what I said, either didnt use one or left the original on there Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted May 28, 2005 Share Posted May 28, 2005 its a rubber ring that goes around the shaft of the dizzy you get it in your gasket set its a oil seal Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 28, 2005 Share Posted May 28, 2005 oh that i threw that ut and used the old one hahahahaha i thought it had something to do with the oil pump , then i broke the pump ...so i biffed it then realised what it was for after hahahaha Quote Link to comment Share on other sites More sharing options...
esky boi Posted May 28, 2005 Share Posted May 28, 2005 Haha yea I just used the original one too, couldnt work out what it was for, but then realised awhile later lol oh well, havent had any problems with it. But have you ever noticed how often they give you the wrong part. Like when I got all the bearings and stuff for the pinto, they gave me .005" oversize thrustwashers, when clearly they were standard Thats not the only experience ive had like that either... Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted May 29, 2005 Share Posted May 29, 2005 O rings come in different section thicknesses. It wouldn't surprise me if the wrong thickness found it's way into a g/set. It should sit ONLY JUST proud of the body. I think it is there mainly to seal against crankcase pressure and possibly some oil splash from the oil pump drive etc. Use the old one if it's not too hard or try Vaseline on it. Eddie Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted May 29, 2005 Share Posted May 29, 2005 yeah problem is i cut the old one out to put the new one in haha ive tried oiling the hell out of it and still no joy... might try using a cable tie like a ring compressor is used and slotting it in Quote Link to comment Share on other sites More sharing options...
