WDE_BDY Posted May 27, 2005 Share Posted May 27, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
davidian Posted May 27, 2005 Share Posted May 27, 2005 whats the brake booster like in an anglia? is it a long mofo in the same place as an esky? Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted May 27, 2005 Author Share Posted May 27, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
Jerm Posted May 27, 2005 Share Posted May 27, 2005 Should be ok, pushrod will definantly know... or look on trademe i think there is an anglia with a prexflow with sideys.. diff enginge but much the same so you will be able to see the proportions.. otherwise id be keen to buy the engine or carbs Quote Link to comment Share on other sites More sharing options...
Pushrod Posted May 27, 2005 Share Posted May 27, 2005 Id say the battery would be the big thing in the way apart fom that you should be fine Quote Link to comment Share on other sites More sharing options...
Pushrod Posted May 27, 2005 Share Posted May 27, 2005 I think you should be alright with the masters but I cant be sure im not near my car at the moment you could convert it to escort struts and rack and pinion if you have all the gear can be a bit of a mission though Quote Link to comment Share on other sites More sharing options...
Pushrod Posted May 27, 2005 Share Posted May 27, 2005 Ok after having a look at my car and doing a bit of investigation sideys will clout the master cylinders Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted May 27, 2005 Share Posted May 27, 2005 Non xflow carbs on LH side, xflow on RH side. Offset the mounts if necessary. Eddie Quote Link to comment Share on other sites More sharing options...
Pushrod Posted May 27, 2005 Share Posted May 27, 2005 Im told they used to run hillman imp master cylinders with remote resevoirs but if you were really keen on sideys you could go for a milton pedal box and mount the resevoirs wherever you want thats starting to get a bit pricey though Quote Link to comment Share on other sites More sharing options...
mkcortina Posted May 27, 2005 Share Posted May 27, 2005 I had to use a willwood pedal box with the master cylinders under the dash. willwood peddal boxes dont come with gas pedals so i had to use another brake pedal for it. i had to use short throw tilton master cylinders. in total it cost about $1000 Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted May 27, 2005 Share Posted May 27, 2005 All the Eskys with the Kent based motors and twin sidedrafts have had offset mounts for the motor with no detriment. Usually combined with a Lotus angled g/box mount but this could also be done by slotting the holes. I think you might have problems with the Escort struts because of the difference in steering system( perhaps the Escort xmember and rack?) Bump steer could be a major problem. We used to speed up the Anglia steering by shortening the steering arms and drilling then forging the taper with heat and an old balljoint. If you decide to stick with a downdraft then the 40/40 DFA from the v6 Zepher is a good alternative. The simultaneous throttle opening gives less economy but lots more response and the 40mm bores more top end. All the rally cars used Hillman Imp m/cyls for the pedal boxes with remote resevoirs however a pedal box does seem an extreme solution. Of course when it was not uncommon to see Anglboxs with sidedrafts it was with the nonxflow putting the carbs on the pass. side and didn't need to be offset. And the sump and pickup will need to be changed if you retain the Anglia xmember and steering. Eddie Quote Link to comment Share on other sites More sharing options...
510WGN Posted May 27, 2005 Share Posted May 27, 2005 Did anyone see that Mint as Blue Anglia [bADBOX] at last years Nats show in Auckland? My Boss built and owns that and is fitted with 1600 x-flow with twin 40mm side draughts. If you want I could find out EXACTLY what he did to fit em for ya. I know that he made up a big linkage setup and mounted some form of late model Jap brake master cylinder up the front of the engine bay and under the carbs. Quote Link to comment Share on other sites More sharing options...
Ned Posted May 28, 2005 Share Posted May 28, 2005 cool, that would be good. now i'll just have to con my dad into doing an engine swap in his anglia Quote Link to comment Share on other sites More sharing options...
Pushrod Posted May 28, 2005 Share Posted May 28, 2005 Id be keen to know what was involved if you could ask him Im sticking with a pre xflow in my Anglia but am curious of any problems he may have had with the xflow and carbs Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted May 29, 2005 Share Posted May 29, 2005 Hey Pushrod, if you're thinking of sidedrafts on the non xflow then you need to look at an extra bolt mod on the carb manifolds. It goes between the inlet pipes near the top. You drill the manifold to 5/16 ths clearance and the head is drilled and tapped to 5/16ths UNC. It will be directly in line with a hole for a head stud but this is fine, no problem. Use capscrews for all your manifold bolts and a shortened down allen key to tighten. Shortened on the end that engages the capscrew. Without the extra bolt the sidie manifolds will work loose and start to suck air. Make sure your manifold plates are the same thickness for inlet and exhaust other one is never properly tight. Eddie Quote Link to comment Share on other sites More sharing options...
Pushrod Posted May 29, 2005 Share Posted May 29, 2005 Cool eddie thanks for the info might be a while before some sideys even get near my car though The swap might be a bit more involved on a 100e too DVLRCR Quote Link to comment Share on other sites More sharing options...
mkcortina Posted May 29, 2005 Share Posted May 29, 2005 yeah i might look at that as well. pushrod you will need a manifold from burton power as the ones they sell at autoquip dont fit even with modifications Quote Link to comment Share on other sites More sharing options...
AE25 Posted June 12, 2005 Share Posted June 12, 2005 hey callum i have a hillman remote booster i bought a while back and didnt use if you go that route how bout a brake upgrade and run boosterless? Quote Link to comment Share on other sites More sharing options...
