Guest ldgracie Posted March 7, 2005 Share Posted March 7, 2005 Having problems with oil feed on the turbo Pinto. What sort of size oil lines did you run as a feed and what size as the return tot he sump? Quote Link to comment Share on other sites More sharing options...
RT Posted March 7, 2005 Share Posted March 7, 2005 6mm high pressure oil rated flame resistant feed with 1.8mm restrictor (carb jet). Return is 12mm piping. (inside diameter) The return is only gravity driven so it must be as smooth and direct as possible..no sharp kinks etc. Quote Link to comment Share on other sites More sharing options...
RT Posted March 7, 2005 Share Posted March 7, 2005 BTW, ...don't ever..ever use running in oil or even crap oil in your engine. The turbo will die a quick death trust me. and watch the restrictor, if you use one, isn't placed too close to the turbo. The heat will coke the oil in the restrictor and block it and you won't know until your turbo starts blowing smoke.... Quote Link to comment Share on other sites More sharing options...
Guest ldgracie Posted March 8, 2005 Share Posted March 8, 2005 Cheers. Might have to look at the return line its 3/4" id but I can't remember how free it was into the sump. The feed pipe should be right but i'll try the restrictor at the sender unit. Have had one start smoking but in fairness the car had been sitting without been run for about 12 months. Quote Link to comment Share on other sites More sharing options...
RT Posted March 8, 2005 Share Posted March 8, 2005 Well I don't kno what type of turbo you're running but if it's anything like a T25 you have to use a restrictor of around 1.8mm If it's pure grey smoke at idle then it's burning in the turbo. Mine smoked like a train then I found out I was supposed to be using a restrictor! Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted March 9, 2005 Share Posted March 9, 2005 Restrictor, my turbo that im using has a 1.6mm restrictor in the banjo fitting on the turbo. You cant get much closer than that its factory too I wonder if I should move it ?. Quote Link to comment Share on other sites More sharing options...
RT Posted March 9, 2005 Share Posted March 9, 2005 the if it is directly vertical into the turbo it should be ok as the excess oil will drain down, it's when you have a restrictor in the flat part of tubeing further back but still above the turbo there could be a problem. hope this makes sence. ie. My first feed was a L shaped fitting that screwed into the turbo but was quite short, like maybe 50mm and then the rubber hose connected onto this. The restrictor sat in the join between the rubber and metal fitting. This was no good and ruined one of my turbos So I sourced another factory fitting that was heaps longer so that the join and the restrictor sat well away from the turbo...above the rocker cover instead. see pics: Quote Link to comment Share on other sites More sharing options...
RT Posted March 9, 2005 Share Posted March 9, 2005 the other thing is too make dam sure there's no chance of the oil feed coming off the fitting or the block t-peice! You (& me) should really be using braided hose with banjo's...but that shits too expensive. Just use good quality fittings and correctly sized tube etc cos if it comes off you can kiss both your turbo and your engine goodbye! Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted March 9, 2005 Share Posted March 9, 2005 Ok I think I get yah, and it is directly on top. I bent up 6mm stainless tube all the way from the sender to the banjo fitting and welded it so theres no hose at all, used a flair fitting on the sender end should work havent got it running yet. Quote Link to comment Share on other sites More sharing options...
RT Posted March 9, 2005 Share Posted March 9, 2005 sounds good bro! keep me informed.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 10, 2005 Share Posted March 10, 2005 Sounds good. What car is this going into and what turbo/boost you going to run. Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted March 10, 2005 Share Posted March 10, 2005 TG gemini, low boost 5-7psi its only a carbie turbo 32/36 weber mostly sorted though just got get into it(lay off the bottle) Quote Link to comment Share on other sites More sharing options...
RT Posted March 10, 2005 Share Posted March 10, 2005 A pinto in a Gem?...different Quote Link to comment Share on other sites More sharing options...
zep Posted March 11, 2005 Share Posted March 11, 2005 Nah, its a G series. You got 2 guys talking to ya there RT Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted March 11, 2005 Share Posted March 11, 2005 Yeah G series sorry , want to do a pinto in an Escort one day though. Quote Link to comment Share on other sites More sharing options...
RT Posted March 11, 2005 Share Posted March 11, 2005 huh? ..i think i just blinked and missed something there.. Quote Link to comment Share on other sites More sharing options...
Draizuh Posted March 11, 2005 Share Posted March 11, 2005 someone started the topic. and then burntrubber asked you a question about restrictors Quote Link to comment Share on other sites More sharing options...
Guest ldgracie Posted March 13, 2005 Share Posted March 13, 2005 Yah I started the topic then got lost working on the car! -Turbo away being rebuilt, seals stuffed and bearing had some play. -Just brought brand new (as in never used brand new) carb off trademe which will replace the old one that was getting sloppy. -Intake leak so intake manifold is getting machined flat this week (thought i'd get away with it) -5 spd is in and hooked up -4 pots and 300 dia rotors up front are f****n great. Stops like mates race car with willwood set up Just need the bits back then stitch it back together, run, tune and check then rollcage!! Quote Link to comment Share on other sites More sharing options...
