jaymz Posted August 3, 2004 Share Posted August 3, 2004 i've got a webber dgav 38/40 (i think) off a 2L cortina, so i'm assuming the jets are to big for a standard 1600, what will happen if i just through that carb on? just lean the mixture out a bit and it'll be sweet? or should i get the right carb, I have done a bit of work to my 1600, new cam and bigger valves. cheers Quote Link to comment Share on other sites More sharing options...
Toucan Posted August 3, 2004 Share Posted August 3, 2004 Personally I would try it out before I went looking for a new carb. I was running my single barrel carb jetted for a 1300 on my 1600 before I put my weber on it. It ran just as good, just way less power. So yea, even though its jetted for a bigger engine it still should be tune-able and go sweet. Quote Link to comment Share on other sites More sharing options...
jaymz Posted August 17, 2004 Author Share Posted August 17, 2004 what's a fair price to pay for a good cond delorto manifold and twin side draft carbs? Quote Link to comment Share on other sites More sharing options...
zep Posted August 17, 2004 Share Posted August 17, 2004 I thought the cortina webers were 32/36? Either way, both would go mint on your 1600. Just makes sure it's in good nick and get some tuner to jet it right. You can go to Weber Specialties on the shore to get an adaptor plate / manifold (hopefully). Quote Link to comment Share on other sites More sharing options...
Guest scort van man Posted September 13, 2004 Share Posted September 13, 2004 it should bolt straight on. you might have a bit of a blank spot when u accelerate hard due to flooding but u can re jet a weber easily enuf. my 1300 x-flow went OK with a 2.0 litre twin throat on so all i can say is give it a go Quote Link to comment Share on other sites More sharing options...
jaymz Posted September 17, 2004 Author Share Posted September 17, 2004 I got a carb the other day it seems to work i havn't put it in yet it has a return line. can i run the return line though a y thing through the breather on my esky? or do i have to drill a hole and stuff? Quote Link to comment Share on other sites More sharing options...
