Esky_addict
Everything posted by Esky_addict
  1. Yep brought the online version today before asking on here. Havent got the bloody email from them containing the link though.
  2. Hey @cletus what makes systems with out e-level so hard to comply? I'm kinda thinking that extra $$$ would be the deciding factor on whether I pulled the trigger on bags or not
  3. Is there any threads on here about airbags for beginners, after info about cert requirements like control systems etc Edit just having a peruse of "AIR BAG SUSPENSION CHAT" now
  4. Any regulations regarding suspension travel for a cert like is there a minimum travel requirement before bump stop contact
  5. Sweet. Was thinking along the lines of machining a piece of steel to the same as the bottom of the spring then using a 8mmish washer to transfer the weight out to the spacer if that makes any sense. Should in theory place the weight in the same position as standard. Abit of height adjustability would be nice.
  6. Looking at getting some coilovers for the front of HQ. In the states all the GM qa1,viking type coilovers bolt on top of lca transferring the weight from the lower spring location to the lower shock mount position. Would this type of setup fly in NZ?
  7. @CUL8R might be worth checking out a 1tonner shaft.
  8. Yeh gets a bit awkward with the tube lengths with one being offset and one being centered. Will be going trutrac eventually but am interested in the borg warner center conversion for the time being.
  9. Had anything to do with holden salisbury diffs @johnny.race?
  10. You sure that that electronic ignition doesn't require full 12volts to operate?
  11. I put a msd dizzy in my holden, not sure if EH are wired the same but I just ran a wire from the back of an accessory fuse to the coil for when it's running and kept the original ballast wire hooked up to power coil while cranking. I used a msd blaster aswell but any non ballast coil should be sweet.
  12. Has it definatly got the right coil in it? Using a non ballast coil in a ballast ignition can cause problems
  13. If I have a current wof, then go for a cert do I need another wof check? Only asking because local certifier likes to see a wof check sheet passed on everything except the fact that car has no cert. Not sure if this is just the way he does things or not.
  14. 100% opposite down south. VTNZ were cunts and the VINZ joker was mint to deal with. Was just a good wof check for me, which is all a rerego is supposed to be (a side from the extra admin side of things). Vtnz basically said that if the car wasn't completely restored minter then it would be a fail. What's the difference their names only going to be on it for 6 months lol.
  15. Haven't load tested battery in car but starts 173 and was starting xr6t fine, the ups battery was tested when they were taken out and all the rooted ones were turfed. Lol yea I was oblivious to the whole impedance thing when i had the stuff in other cars I just thought that the juice couldnt keep up. Problem looks to be semi solved just buy wiring the dual voice coils in series instead of parallel.
  16. Some good info there, Yeah I realise about the hole PNT situation, car in question is a hq holden very similar to my DP pic actually... it is going for a rerego in the new year anyway but just had me thinking about the loopholes. I'l probably get crucified for saying this but IMO there's certain situations where pnting a car isn' such a biggie, If I know a car is legally owned as has been pntd as a means to get a old smoothie back out cruising on the road i would sleep fine at night. Victimless crime unless your a dirty theiving mongrol prick then you shouldn' be allowed to share our oxygen, I am not and am more interested in the cars than the politics. ✌
  17. Was thinking about people for example rolling a hilux and chucking a good body on then back on the road again as the same vehicle... which I see no problem with anyway just like changing a body panel panels except they change ALL of them lol. Or replacing a rusty chassis with a good one keeping the body's plates. Do that to a vehicle a couple times and it turns a bit like granddads axe lol another "hypothetical" situation is someone having a dead reg car, some live plates and a subframe which may or may not have a chassis number stamped into it which matchs the also hypothetical live plates.
  18. yeah thats what I thought bit of a grey area aye.
  19. so when there is a chassis swap done on the vehicle its still identified by the body? not the new chassis
  20. What does a cars plates need to match upto? like would it be legal/possible to wof a derego car with live plates and matching chassis or subframe?
  21. And its pretty simple really only need to add another earth to setup. Cheap alternative to a capacitor.
  22. They were cutting out but after some googling last night that may be because they are DVC subs wired up to 1ohm and this amp is 2ohm stable.
  23. Oh yep sounds good. Anyone know of a good site to get some info on wiring subs up to an amp properly, I've dragged my old subs and amp out to chuck in hq, I haven't had them in a car for a few years and am not sure I had them wired up correctly, they are rockford P2D4-12 subs and a PRS-d1100m pioneer amp. I'e just been having a look on the net about the different ways of wiring them 1ohm 4ohm etc
  24. that' not a bad idea. would it kind of defy the point of a 2nd battery though as it would isolate the batterys when you need it like when the bass hits or am I missing something (VSR That is)
