Celica RA45
Everything posted by Celica RA45
but you know have the link ,wouldnt a set of black tops and your mates inlet give you some more power going by using tps for power also try a std altezza clutch and pressure plate thats what i use ,trick is double strap the pressure plate
why dont you just spend the money and get the 2 stage sorted with a dyno tune or get some 48mm quads and 1 manifold and go quads ,that has got to be better and then bolt some 2 stage on it
mine are on a angle to give more caster
or ask rookie ,he seems pretty clued up on k20 motors etc
well try kelfords and ask them they will be able to help
and you didnt answer my 1st q on the rocker arm geometry
look for ra60 and ra40 should be the same
and dave you can buy a kit that bolts to your rear end and you can re lower your rear trailing arms .they have 2 new positions for the traling arms to attach 2
the k20 has rocker arms are you sure if you work out the ratio that they have the same as direct on bucket as in 260 to 320 duration or are you looking at the high cam and not the smaller 1 most cam on buckets are 1 to 1 ratio the k20 might be 1 to 6 ratio etc
Celica RA45 replied to Truenotch's topic in Project Discussion
just had a thought ,with all the racing that you have been doing ,i would take it out and get it checked for cracks especially since it was done in the 90s -
clean it up with petrol and use the toyota packing sealant that they use on the sumps to blocks ,just make sure the inside is real clean and smear it all around until dry ,this will stop the leaks,or take it out and get it sealed up with more weld -
the honda would have a different rocker ratio than the direct on bucket set up
i use 50 /50 1 litre of dextron 3 and 1 litre of 80/90 for my race car box with syncos and works well
glenns new RA 45GT celica with full on race beams
Celica RA45 replied to Celica RA45's topic in Projects and Build Ups
ok have finished off the front of the car with grill and head lights with new lenses for the front bar and have put the canards on the side of the front spoiler . also have roughly fitted in carbon race seat to see for height and leg room -
no they were designed to fit onto a 33mm bucket ,also running a 98lb spring seated
easy the cams i have at the moment are 560 thou lift with some vvti on inlet and 540 on the exhaust pearce has a set as well
yeah thats real good the best we have had from a beams head is 340 cfm at 550 thou lift in 28 inches
and the biggest quads i have seen on the hondas is 52 mm
is the honda k series motor running the cam direct on bucket or do they set the cams the same as sr20 with hydrolic rocker arms
Pe-arce's Mk1 Ford Escort Beams Powered Race Car
Celica RA45 replied to pe-arce's topic in Project Discussion
just make a mount behind the seat for the tank and box it in ,so when the seats not in you can get to it easy- 114 replies
so where you have the tank in the pic ,can you still put the seat in ,also with the full lock and the weld in sections ,did you take the springs out of the shocks so under full brakes the tyres wont hit and scrub the new tyre wells- 114 replies
put the oil tank behind the passenger seat and box it out with a lid on the top .that way you can have the best of both worlds .my tank is only in the front passenger side tower as i need weight there to try to balance out the weigh tof car with me in it- 114 replies
crank bolts need loctite on threads to stop oil going onto flywheel
glenns RA45 GT celica with race beams
Celica RA45 replied to Celica RA45's topic in Project Discussion
look at those axles dave and compare them to the disc brake rear 1s also the rear ends are alloy .this 1 weighs in at 60 kilos with brakes and center .the other 1 with the group C brakes and rotors is 85kilos -
ok up dates with cambered rear end is in ,this rear end takes 3 litres of lsd oil and weighs 25kilos lighter than the other F series with big axles and bearings with the brakes .have now fitted the dry sump tank ,finished of the rear 1/2 fuel line from the tank to fire wall,.. finished the rear brake lines to the rear end etc have also done the radiatoras well
