Posts posted by Valiant
Can anyone recommend a hobby turning course in Christchurch?
I'd like to up skill, learn more basics/fundamentals.
I've used scraps of panel steel tacked on with a mig. Worked well.
+1 for what Clint said.
I have delt with Sheffield Crescent auto center with my Valiants and found them to be very helpful.
https://fuelsforum.rasoenterprises.com/viewtopic.php?t=75
Pushrod 250ci on dual fuel.
425 impco gas carb, E model convertor with a boost reference.
Put the gas carb in front of your efi throttle plate with a silicone reducer. Job done.
Bonus high octane fuel to boot.
There's a 425 and E model on trade me at the moment for $300. I think it includes a tank.
@ajg193 if the rack adjusting pad is too tight the steering won't self center out of turns etc. Your car will be like driving a forklift. Is it not driving like that and doesn't have lots of play you got the adjustment right.
2 hours ago, kiwi808 said:
You clearly don’t rotary.
/308.
I saw one fitted to a BB Chev too it was set for quiet mode and worked well.
Shoes look ok
Cylinders are stuffed.
Replace the lot if you're feeling wealthy.
Once its all bleed up you will have to adjust it manually through the back plate. Adjust it up until the wheel wont turn then back it off until it turns freely.
Edit.
Chances are if the pedal is low now it's because the adjusters have been backed off.
1 hour ago, ThePog said:
the size was a real constraint as it had to fit into a 300mm cube.
Hence the short barrel?
Very cool.
I really like your intake manifold, and the use of a lay shaft im looking forward to seeing how that progresses.
My only complaint is that carb flange. It's not for an Impco gas carb, which would be fantastic in my opinion. Imagine supping that high octane low price goodness.
Owning this car is great.
It never uses any fuel because its in my garage on stands all its life. I think I filled its tank twice since the last update.
The gearbox pilot bush started to chatter so the box has been out and in.
Steering wheel frame broke so that's been off for repair.
Engine revs now like it should so I tend to rev it more necessitating construction of a crank case breather.
I have no photos of these fixes but I assure you that they have are completed.
Anyway. This has been a bit battered body wise the entire time I've owned it. When I got it in +/- 2005 it had been a daily driver, caravan tower, take rubbish to the tip car. It had always been garaged but old Johnny had been struggling to steer it and took out the letter box and gate post in the time not long before I brought it off him. Its always been a little bit rusty in the bottoms of the front guards and the bottoms of the rear quarters, I've always intended to fix this stuff, get the battle scars out of the front guards, fix the holes from a long broken rear view mirror etc. now with lockdown giving me time to complete a number of more pressing projects I've taken the plunge and got stuck into this. I have some repair sections for the rear quarters that I made at tech about 6 months after I got the car, cant rush into things.
Crusty quarters.
Ill just put a patch in the bottom of the guard, that's all I'll have to do.
Nope, end of the sill is rotten and the frame.
Pretty happy with progress so far. I've rust killed everything, and blown 50 years worth of detritus out of the sill. Once the rust killer is dry I'll PA10 it all then weld the piece in place.
Then it will be time to start on the guard frame and bottom,
- 26
My 2c.
Make some good solid clamps for the front of the leaf spring pack.
I also made some bars that went from the top of the axle tubes to the chassis, like the top half of a 4 link set up. Just make sure the distance of your new arms is the same as center to center as the front spring eye to the center of your axle.
It worked well for my car, I used the watts links off a falcon with the pivot cut in half and welded to the axle tubes. It kept everything up above the ground.
Perfect.
Thanks.
This would a very cost effective option.
I'll cover it in petrol and real flames before that happens.
Make a new key out of steel. It takes a bit of filing and testing but works well.
I used to make them regularly for my IT.
Thank you.
Your prep work and application look great though.
I like that. Something to get done in the future.
Thread revival.
Can someone make the roof on my Valiant the same burgundy as the wheels from the top of the A pillar to the bottom of the C pillar?
Thanks.
Slackness on my part.
This is all signed off now, runs really nicely on gas, goes great, better and smoother than it did with the Holley fitted previously.
I've wanted a sunvisor for some time so about 4 months ago I splashed out and brought one X Australia.
What a scene.
Anyway I finally got it fitted today and I think it was worth the wait.
- 26
This is awesome Chris!
More details please, motor? Transmission? Diff? I hope it gets complied ok.
How exciting
Edit.
@CUL8R come on mate.
I see big block headers.
Toyota 2e Timing marks...
in Tech Talk
Both keyways (cam and crank) should be at 12 o'clock. From memory.
Is that the case?
