Valiant
Posts posted by Valiant
  1. ^This is why LPG has a bad rep.
    The pressure in the tank doesn't decrease until the tank is on the brink of empty. the tank pressure is due to LPG boiling at room temperature.
    "As its boiling point is below room temperature, LPG will evaporate quickly at normal temperatures and pressures and is usually supplied in pressurized steel vessels. They are typically filled to 80–85% of their capacity to allow for thermal expansion of the contained liquid. The ratio between the volumes of the vaporized gas and the liquefied gas varies depending on composition, pressure, and temperature, but is typically around 250:1. The pressure at which LPG becomes liquid, called its vapour pressure, likewise varies depending on composition and temperature; for example, it is approximately 220 kilopascals (32 psi) for pure butane at 20 °C (68 °F), and approximately 2,200 kilopascals (320 psi) for pure propane at 55 °C (131 °F)."
    It sounds like your Triumph needed a good tune up, possibly a convertor service and maybe the heater lines cleaned out.
