Everything posted by Stu
TD42's are known as a kettle so make sure you do everything you can to keep them running cool. In my opinion 100 degrees is way too hot to run them at but worth a go and see what its like. There is plenty of info on how the thermostats work on the aussie 4wd forums Here's the gauges I ran, shit photo but you get the idea. They are 24v gauges from aliexpress and were about $25 each from memory. They come with a programmable warning light and outputs for fans/warning bells/relays. I bought one with red numbers for the EGT and green for the water temp. I ran a thermocouple in the exhaust manifold pre-turbo for EGT and another one in the thermostat housing for the water.
We had Acorns too and same thing, Ive been trying to remember a game that we used to play! One day it will click!
Looking great! I can recommend running a hi flow lower temp thermostat with these engines if you are not doing so already. My Safari ran at 80 degrees just about all the time with one and a triple row radiator. I can fully recommend the Auberins digital gauges too - I ran them for EGT and water temp.
Yes they do, pretty low amperage ability from memory
You love wiring
I've got both factory seats and will probably roll those for the wof. Pump up lumbar support is lush!
Stu's 4agte 85 EP71 Starlet and 4age 84 AE86 Levin
Stu replied to Stu's topic in Projects and Build Ups
Forgot a photo, here's the inside in all its dusty shitness. Should clean up good though. Wont make it to OS drags but I'd rather get this together properly than thrash on it and have to do it again later.- 31 replies
- 5
Plan is to finish wiring Richies KP then hit this thing hard. For now have swapped out the front carpet as it was a bit shit, and fitted the lights. Its back in storage now. There's a looooong way to go.- 31 replies
- 17
- 31 replies
- 24
Can confirm this thing is white now - no photos yet.- 31 replies
- 5
Yawn... Might slap some white on this bitch next week. Also might not.- 31 replies
Just set the limiter settings so they are really soft acting in the ecu you are using.
All good mate, hopefully he can help
You could give Robbie from RIPS an email too - if there's anyone that knows about RB's its him. He's good a pretty good guy and while he builds mega dolla RB30s he's usually super helpful to the average Joe.
Thats the plan if the paint is done in time!
Rust repairs and painting gives me the shits, would much rather be doing exciting things... like smokey 11's Anywho, some more progress, back bumper was hiding some gems which needed dealing to.- 31 replies
Just a waiting game while the painting guy does stuff. I decided to take the side trim off so the guards needed a bit more work but are all in primer again now. Body is coming along very slowly. Front bumper is off to get fixed as theres a few cracks in it. Painting is boring so just one photo for now. In other news these arrived... finally. I run FA stuff in the EP and its pretty good, so thought Id have a stab at it for the AE too. Spenny, but hopefully worth it. Went with 8kg and 6kg and the shortest possible rear shocks. Will order some new bearings and maybe rotors sometime soon. No rush without the car here.- 31 replies
Slowly but surely- 31 replies
- 18
Exactly. There are cheaper sources again if you hunt around.
I have a source... if it doesnt work out send me a PM
It is just a three port solenoid you need?
So much 20v love Good job I have the best 16v there is... stock bluetop awesomeness! Remember kids, rev til bust!
Little bits and pieces starting to come together now on the 86 - painfully slow but any progress is good progress right? I've fitted the new water pump, cleaned up and painted the coolant bypass hard lines, picked up new radiator hoses and have the heater hoses ordered and on way. Front of the engine is coming along with the hall effect sensor on the crank mounted, still have the sensor for the intake cam pulley to do but hoping to knock that off next week. I've found and mounted up an ae85 radiator overflow/washer bottle in the front drivers corner of the engine bay as the ae86 one will melt over by the headers I think. Found a brake reservoir sock thing to cover tidy up the faded gayness. Am in the process of cleaning up and painting the brake lines so I can refit those, have some braided lines to go on. The drive shaft is now in with new bolts and a new gearbox rear seal. Tidied up and painted the strut brace mounting plates. Exhaust is almost done, just have about 200mm of pipe to do from the merge collector to the rest of the system to build. How its looking currently Also picked up this which is now fitted: And this which isn't fitted Pulleys are sitting on the cnc machine so will have them done next week all going well.- 31 replies
- 19
So I looked at the prices of aftermarket pulleys and said to myself "fuck that, I can make those" so have drawn them all up and will be putting them on the cnc lathe soon. Idea is to make myself a set and get them anodised. Will likely sell these eventually too, have got fwd and rwd water pump pulleys drawn up and the alternator pulleys so yell out if anyone is interested. These are underdriven too. Nearly there with the design, just need a few tweaks to give some added strength and make them easier to run up on the lathe.- 31 replies
- 18
The middle one: As long as its complete and not cooked im pretty keen!
