Everything posted by JoKer
New Set of Gas struts for boot on the way, Barry'd the Glove box hinge with a 10mm Galv bolt (now it doesn't fall on your toes) and found the Trailer plug tucked in a side pocket 'tis the newest car I've had in my possession!
Popped up on the Tard as a Trade-in Picked it up Cheep & is as advertised & what I bought, so not unhappy with it Plan on a Service & decontamination then some light Work Duties 2001 VX V6 3.8 Auto High KM's and tints : Perfect! if under what I was shopping for it will do for now Original NZ Owner was a Barry! So this is officially my Barrymobile Aftermarket Sterereo so does anyone have experience rewiring the Steering wheel controls? for say a Pioneer or Sony Head unit? edit :these do-hickeys? https://www.qualitycaraudio.co.nz/car-stereo-983/head-unit-accessories-67/steering-wheel-control-99/ 2nd link : https://www.wavetech.co.nz/search.php?s=steering+ (for my future reference) &I'm now told I need this if I want it to work : https://www.wavetech.co.nz/Axxess-ASWC/ answered my own question : carry on Barrying Found $2.20 and a Black Bic Pen so far : winning?
lush
JoKer replied to h4nd's topic in Other Projects
yeak : I have seen "bucks" for the Buck's online but never got round to finding or making a full body, worst part about makignthe Trex or Spider (2m i diameter / tall) was tripping over it in the factory. ended up giving them away, this guy i have on the wall -
yeah this thing, pretty sure I posted it here before but free bump- 1293 replies
unbolt whatever is at the top? What kind of car?
So a guy from Taupo gets in touch, He's restoring his Mk 1 Avenger (Have learnt in the UK they refer to them as Mk1's & Mk2's for the Classic shape & Chrysler / Later shape) Has misplaced some very important Plastic pieces for the accelerator peddle & would I mind checking my 'stock' So I Send him images of these two (Brown 72 1500 & Blue 76 GLS Apline) and this location of the stuff he might need and my Accelerator pedal for comparison Man says YEP the green bits & oh my yours have already been lost, I had seen the "U shackles" before & thought thye were not right and they allow a fair bit of slop but are working for now so I can spare at least one set of Bushes / set of 5 plastic pieces he needed then he sent me an image of his car Oh LOL TWINS! Auto even SO I get to stripping, the easiest one, instructions were remove the seat & steering wheel to get better access Jobs already half done on this one Figure while I'm at it might as well strip a few other goodies out of it Headlight switches, What does the internal turner do? (serious never had one or played with a working one) Lol Shear bolts on Ign 'not sheared' Dash not bad, lol no rev counter in Manual? not even a Clock! Light fitting in the glove box! What is this madness! (checked My GLS & it only has a 'hole') So dash out & rescue these parts, so at least I know how to get them out of the brown car should my U shackles fail Might be worth 3d Printing some one day though not expensive from UK from the sounds of it Back of the Dash 31? or 13 got looking at the Dash & LOL 4 digit Odometer? WTF (turn screen) So I have a thought as my Coolant temp gauge is iffy & my Volt meter had lost its lettering why not rob / swap some parts over was Simple enought, 1st test drive I had forgotten to plug speedo back in LOL even from the same year its crazy to note the differences on the back Mine is the Left Blue car / donor is the right so yeah, Coolant temp works better now & My Volt Gauge says" Volts" and I figured out why the Handbrake warning light doesn't work : there is not circuit in the loom for it! may get around to that one day
one of them Razorr Drift karts and
Wheels on Windsor Car Show March HB 11th 2018
JoKer replied to JoKer's topic in Lower North Island Region
@BillyTong get'er going for this! -
MAR11 Wheels on Windsor Car Show Public · Hosted by Hawke's Bay British & European Car Club Inc.
so ah Point #7..... are we Austrailia Now? heh pending interest in daylight activities
Low'n'slows Vauxhall Chevette 10 second car
JoKer replied to My name is Russell's topic in Project Discussion
you what? Black plates mean that on those? I thought it was only if you could see the Lights on the car (clear visibility / not over loaded) I threw blinkies on my Blackie just to feel better towing it -
derp shoulda known, yeah will do man, probably in the Wilf thread tbh : I''ll go digging
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
SO I know of one of these there need to investigate a tad further , how would I identify the Gear bag should is still exist? good ol Wiki says : Transmission 4-speed A40D automatic 5-speed W55, W58, T50 manual uless someone knows something I dont? the last w55 I had in my possession I gave away (unknown condition)
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
yeah, car already kinda has the setup just never operational (bit like the Nut behind the Wheel just unsure of how effective the hyrdo system is in it etc (willwoods may require upgrade or bias valve too
mechanically speakign is it possible to fit the above brake system to the Avenger / with drum brakes? (not so much a cert Q soz) vs the cable click click etc?
50:50 just want it to go vs doing it right hence doing homework even before tearing it apart while it still moves in 1st & second (and R)
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
oh GOD the science, I'm hooked!! yea Wagon Diff's are 4.11 (low ratio for hauling) good for Rally application, to to stressed about the rear end for now as you point out tires make a difference, pretty sure i have a 3.9 diff currently (welded / locked solid) Richard aka @Avenga has mentioned he's had his 1500 Avenger to 200kph on Puke with the Sierra 5 speed (not sure which gear, & similar setup cams & build) so yea you have a great point there, keen for something tweakable at some stage or get a setup thats not going to limit me to re-using 40 year old gear sets / stuff that's rusting & rotting in my back yard shoot could put it over a bank 2 days after (whenever) its done / Whariti Hillclimb is February kinda my goal at the moment (NZ Longest Gravel Hillclimb!
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
I'm ok with this Happy / half my intention of thread is to discuss the 5 speeds option for any 4 speed upgrade ratio's for me are not really an issue currently, just the mecanics
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
still the actual Plan, wander down to WIlf's #RIP yard or any other wrecker & scrounge a t50 toyota shell for $200, get clutch, box maybe pedals & bits & sell rest to foamers & get Rich to this then stare at it for anther 5 years the CR stuff mentioned was in the Avenger Gearbag Miles was using and Craig Dino in Chch in his Blue one he's also using a type 9 in his white one any t50 would not be 'built' until I break it as well wouldn't stress about the w50 for now cheers, mans allowed to dream
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
Hmm sounds like a goer / proven at least
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
B Bell housing tho (Of B/C Fame) worth it just for that I potentially to collectors, cant be many of those around still (NZ Made Speed parts what sort of stuff required to make that work, figure "just" right diameter Toy Clutch & spacers / shaft output? Literally learning from Zer0 here
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
geddoutofit Thread jacker! apparently the BW45 (4 speed auto) was similar or same as some Valiants / Chargers?
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
2014 & this would have been on the Yellow line Graph Gees I've missed doing fun stuff in this car! need some more gears if anyone has wisdome happy to chuck a spare 4 speed back in but while its out.. well you know...
Hah nice yeah I know at least one Toyota that works in Miles's Rally Avenger just waiting to see what his specifics are this is his other toy
- 39 replies
- avenger
- more speeds
(and 3 more)
Tagged with:
