I just got this Rambler transported up from Christchurch last week, so at this point the plans are to actually drive a car and enjoy it for once, instead of having it in a never-ending project mode. I'm sure a full body restore + respray will come in the next 6-12 months but for now my goal is to lower it and just drive it around for a few months at least.
So this thread won't be anything mindblowing, just keeping a classic running and giving it a tidyup in the near future.
It's a 1966 AMC Rambler Classic 770, running stock (even matching numbers) 6 cyl 232 with 3 on the tree. NZ new, first registered in Christchurch, and it's been there up until last week. 3rd owner had it since 76 until 2010, and then last owner before me only seemed to take it out for WOFs and drive it about 50-100ks between warrants. The paint is original, pretty rough but very very clear of rust (for a car of this age). I suspect I'll fail a wof for some surface rust around A pillars, but that'll be a good reason to strip it all down and do a full panel/paint.
I went to rip the suspension out of it to try and match it to something a bit more common, and thanks to the good people on this forum I found out that this is running "Trunnion" front suspension which requires a purpose-made clamp and using car's own weight to compress it by jacking the opposing rear corner. Although now I've had someone in a Rambler Facebook group tell me how to pull out the springs without it, but I'd rather not risk my life for the sake of sussing out the right part so will do it properly. So this will have to sit this high for a bit longer until I sort out this clamp.
It runs drives / has WOF, Reg. Well, it drove when I dropped it at the transporters week and a half ago in Chch, got here empty on gas and flat battery. I suspect it was left running, ran out of gas, sat there for a bit and fried my points. The points are gone, so I'm replacing them and the rotor at the same time (picking them up tomorrow). Will then blow the fuel line through just in case and will see how it starts. A bit annoying but small price to pay to get this beauty up here.
I'm the 5th owner, this is the first time I've owned a car of this age where I had the original ownership paper, and the plates and engine matched. So the ownership cert had to go in a frame, pretty anal I know, but I don't know if this will happen again so might as well make the most of it:
There seem to be bugger all of these around, trying to find any parts for them all shops seem to try and juggle between other models of AMCs, so ill start a list of all parts that seem to fit this particular model, and if anyone happens to come across one of these in the future and needs parts, at least there will be a reference of what parts to get:
Ignition
Points - BOSCH GD 501C
Distributor - Cardone 84-1646 or Cardone 301646
Suspension
Front shocks: XA Falcon (TBC)
Rear shocks: LH Torana (TBC)
Front springs: VB-VK Commodore (TBC)
Rear springs: ? will find out
