Everything posted by cletus
znoelli ones are usually ok. such a weird name. i wonder how much business they miss out on cause people cant spell it
yep, theres a couple of other things to look at with adapters- narrower ones like 15mm sometimes dont have enough material under the taper of the nut or under the head of the stud. from that point of view yours look ok as the nut sticks out heaps another thing i find a lot with cheapy chinaspacers is the taper of the nut doesnt match the taper of the adaptor- and the nut thread sometimes isnt machined parallel with the taper so the nut is slightly on the piss, all this leads to the nuts coming loose eventually
//oldschool.co.nz/index.php?/topic/17433-for-questions-regarding-wofscertsnumber-plates/page-95
yep no worries, as its really only designed as a bumper holder upper rather than a crash slower downer
as far as cerferoes go, the lowest i usually cert them at is 310-320 in the front (depends on rims/tyres) and 300 in the back. other certifiers may have different ideas on that. they start to handle like poo any lower than that, the rear toe change over a bump gets quite noticeable if that falken sheet says that size is fine, all is good. older pre frontal impact requirement cars dont need to worry about cutting up bumper irons
better than some of the "panel shops" up here keep up the good work
sweet car. will be cool with those triples and rocker cover etc may i suggest loading up that cam with break in lube before you put its pants back on
I GOT 99 PAGES, CERT PROBLEMS ON EACH ONE Redrilling 4 to 6 would be fine if theres enough thickness under the stud head
you can, depends on the design as to how it would have to be done. Whatever you do, it would need to be certified. //oldschool.co.nz/index.php?/topic/37800-welded-strut-how-to/
Andre's vauxhall magnum into Firenza droopsnoot project
cletus replied to yoeddynz's topic in Project Discussion
nice work! -
It is still valid, if you have a 2 piece shaft then its usually no good because they are short sections, the loop needs to be at the front of the shaft. that 150mm measurement is only the MAX distance from the u-joint, you can go closer to it, that might make it easier?
can be done on a pre frontal impact compliant vehicle you cant make it weaker, or significantly stronger than it was originally cost wise, depends on what else is modified and who is certing it, there isnt a set price
if that replaces the rear shock ie the weight of the vehicle now goes thru the shock mount- might be possible with strengthening, i havnt seen it done on your sort of car only lighter stuff like starlets, corollas etc. IMO from what i can see in the pic they look like a bit of a cockup anyway, that spring would coil bind at that adjustment height, looks like lowering the spring platform would result in it being uncaptive so you would need keeper springs, cant see any bumpstops unless they are up in the mount tube thing but then they wouldnt be doing anything. i dont rate bilsteins much either, i have found a few issues with them
just the usual 'fit for purpose' deal, and have to have a bumpsteer check for certification, as far as i know you shouldnt have any issues if they are for your 64 theres some around that are welded together which are a hassle to get legal but these are for early 50s fords i believe
Talk to the certifier you plan on using, but last time i certed a 64 i didnt get them to fit a second loop, because of the design of the chassis making it pointless/very difficult to fit
the way the rules are worded, any mods to original front suspension arms need to be tig'd and crack tested.
depends on the quality of it, at that price i would question how good they are, welding looks pretty poos. cheap arms usually have super shitty joints which flog out quickly
angles should cancel each other out for no vibration, if your rear susp arm bushes are a bit squishy pointing the nose of the diff down a little bit can help, as it comes right under acceleration
I cant think of a reason why you couldnt do this legally, if you are using a fuel that is legal for road use. As long as the extra fuel system meets the requirements of a normal fuel system. Nitrous can be certed for use in a road vehicle, although i think the intent is for competition vehicles to be able to have all the nitrous gubbins fitted rather than for actually using it on the road. same with line-locks, they can be certed as well. i guess anyone using full jandal runs the risk of being done for "excessive display of acceleration" or whatever that stupid rule is called cars with LPG have to have a yearly inspection (alternative fuel certificate) and a 10 yearly tank test, this wouldnt apply to an extra fuel system if it was just regular fuel.
nothing specific, just make sure its secure and wont fall off with vibration etc
40mm is in the hobby car manual as a minimum amount of bump travel, if you had a similar amount of droop travel it would be fine
also, when there isnt a spec for something, it doesnt mean its possible to use an old coathanger or a hot glue gun to attach an engine/whatever, there is a requirement that everything has to be done to a tradesmanlike standard and be fit for purpose.
as far as LVVTA rules go, it just has to be secured, doesnt have to be enclosed, and there isnt a spec for the tie bolts. as mentioned by yowzer and japawagons though, motorsport nz has different requirements, if you are going to do any competition events then probably best to do it to those rules
