Everything posted by Roman
Stu's 4agte 85 EP71 Starlet and 4age 84 AE86 Levin
Roman replied to Stu's topic in Project Discussion
EP starlets are so damn cool. If I could have a dream garage of cars I think a full bodykit factory turbo EP starlet would be in there. The first time I saw a factory turbo one I couldnt believe it. That and the first time I saw a Z20 soarer stick out in my mind was "WTAF!" moments for seeing cool 80s cars in the wild back in the day. haha. -
Rhyscar's Subaru Type RA of teenage dreams... where less is more
Roman replied to Rhyscar's topic in Other Projects
So cool. In my mind, when I think of WRC. The first thing that comes to mind is the era of WRX vs evo battles for supremacy. Maybe with a sprinkle of Puegeot 206 and ST205 GT4. Everyone loves the group B monsters, but the 90s were a golden age for Japanese performance cars gaining some credibility. Generally speaking. It feels like the rally results helped cement this in a decent way. Having the opportunity to own a homologation version of something is so damn cool. It seems crazy that this is even a car that is in any way still affordable to buy. -
Yeah I guess it only really makes sense if you wanted to run a fully sequential V12, or a V8 with fully staged injection. But even so, at that price point might not even make sense compared to other options.
I downloaded the Link G5 software to see what features it has to control direct injection specifically. And, there's not really much different about it compared to normal injectors. Just some features for controlling the high pressure fuel pumps (which will work differently based on manufacturer etc) and then apart from that, it was just setting up injector data as usual, and assigning them as DI injectors (which presumably puts the drivers in peak and hold mode) However I also noticed there was an option you could select, to make the injector outputs work with the factory Toyota injector driver boxes. There wasnt anything special regarding injector timing or anything else. A few extra features for blending port and DI injection if you were using both. So I'd say it's probably still feasible to run it with a normal ECU that's got 8 injector outputs, so long as you connect to the box. I'd test it here but I chucked that box away already. The 2UR looks to run a box just the same.
On the front of this engine, there is a DI control box. It has inputs from the main ECU, and outputs to the injectors. I suspect it takes regular injector outputs, then beefs them up into the high voltage peak and hold setup for DI. So it might be possible to run that with a bit of homework, but for reasons above I've already biffed all that stuff anyway.
Yeah the main appeal here was the high compression ratio, and aftermarket parts availability from the bigger engines. I dont really have a choice though, even if I had an ECU capable of running it. Because the aftermarket cams are only for the 2GRFE, and they do not have the DI fuel pump lobes on one of the cams. So all that stuff goes in the bin anyway. But the 2UR might be the same. And/or the ECUs of this era will be reflashable. I'm not sure how easy they would be to swap into another car with factory ECU though, and keep it happy with all of the bits that will be missing.
I'm wanting to go through cert process again, but it's unlikely I'll have everything sorted by December. I was hoping to go through a tech inspection so I can make it to OS drags this year, if I can sort everything else out in time.
It sounds like the wheels are slowly turning for a rules update around this topic. I mean Toyota started having full ethrottle cars 3 years before Playstation 2 came out! It's hardly a new technology. It's funny going to nightspeed because the late model BMWs with advanced traction control stuff just absolutely rocket out of the hole on street tyres compared to anything else. But that's not really anything to do with ethrottle, it's more to do with DCT transmissions and ignition cut/fuel cut traction control. Ethrottle is too slow to react to be useful at the drags. It's a bit frustrating, but yeah I guess I will just keep pushing to get all the tasks finished to get the car going. Then just talk to a tech inspector and see how I go. It will be a shame to miss participating in OS drags if this is a hurdle. However I can still get a logbook and enter the car into some other events when it's going.
Yeah I'm using SW20 calipers at the moment with a Primera disc. But I've got an MX5 setup here I was looking to fit at some point. Going back to a smaller/lighter non vented disc, and better pad options for MX5s. That's one of the most important things for choosing a caliper I think, finding something that actually has good pads.
There is an F series that bolts straight in. Mine came from a left hand drive French MA45 Celica. haha! Thanks to @thegreatestben who was wrecking it a long long time ago. Needless to say they are incredibly uncommon, took a fair few years of looking before I found one. (And back when there were a lot more of these era cars around) The only problem with this setup is that it's factory drum rear, so has the skinny bearings. I've got an Estima setup too that I might shorten and swap in at some point. So I can get the big bearings on the axles. As I've worn out these ones a few times already. They start leaking after a while.
The axle tramp this car had on semi slicks or street tyres was insane, the shock loading on the drivetrain must have been intense. I am 100% convinced that squishy drag tyres do less damage to drivetrain than axle tramp. The echo as well, on semi slicks it felt like the car was ripping itself to pieces. On drag slicks it just felt like a CVT, but the wheels were spinning instead of gearbox guts. I'm not too worried about breaking stuff. If it breaks it breaks. One annoying thing. I'm just looking to get some clarification around tech inspection requirements. It seems that ethrottle is banned for drag racing tech rules unless it's factory fitted. So that might prevent me from passing a tech inspection.
This has an F series diff, which is one size smaller than the Hilux ones. I think it will be fine. I've got some spare axles though, and you can buy aftermarket ones that are stronger.
Surprisingly, my current rear brakes fit 13" wheels no problem! I did need to use the spacers to clear the calipers to face of the wheel though. I'm super hyped for drag racing activities! Looks sweet on trailer wheels and slicks. haha. I thought my mate with the 808 wagon was running 1.8 60ft on these same tyres, but he's run a few 1.6s. That is just an insanely fast launch. The best I've ever done in the Carina was a 2.5, best in the Echo on these slicks was 2.09. If I could get below 2.0 sec 60ft in this car I'd be stoked. I'm thinking I'll do my previous trick of extending the bump stops so that it's nearly sitting on them at its resting height, for drag stuff.
- 76 replies
- 36
Yeah they are dimmable and it definitely needs it. On my last one I had an LDR connected so it would dim or brighten in near realtime (dampened a bit) It was amazing, come over a crest so sun is shining on it, could still see it fine. Needs some sort of failsafe though as if it defaults to full brightness at night time itll burn a hole through your head.
A few things going on. Most of the wiring is tested and working well. A few mistakes I made with wiring order which were easily remedied thanks to being able to repin the sub loom plugs. The TPS on the second set of throttles, runs absolutely nothing like any TPS I've seen before, which is annoying haha. It wasnt simply two voltage divider circuits. It uses some fancy chip that looks at the field lines coming off a magnet that rotates, then draws two sine waves that get compared by the ECU to determine throttle position. Or some crap like that. So, that's off to the bin. I will need to print an adapter to put a second "normal" TPS on there. But it's been annoying that I havent been able to test my ethrottle controller yet. Since it's a small fiddly part that needs quite exact tolerances, I shall borrow a favor from @flyingbrick who has an awesome resin based 3d printer. The dimensional accuracy is amazing, he previously printed me a fitting to go on the end of my valve spring compressor tool. Which worked great, and showed no signs of wear or damage after fitting 24 very stiff springs into two heads. Thanks Nathan! Also, I found a cheap set of bogan spec 13x7 4x114 Cheviot US800 wheels that I can fit my drag slicks onto. So that will be cool. Hopefully I can make it to December OS Drags via tech inspection. Even if it means the car will need to be running with standard cams and the crappy factory exhaust manifolds or whatever. Fingers crossed I can keep the momentum up and get things done in time. Another thing is that a while ago I decided I want to run a digidash instead of a factory one. So I made this which worked out quite well and was cool. But I felt like the styling wasn't quite right, and I somehow wanted to use up more of the space on the sides. But couldnt quite think of how to achieve that. In the meantime, with the Echo. I discovered just how absolutely magnificent it is, to have a graduated shift light where the bars start from each side, and meet in the middle. The accuracy on shifting is really amazing. So I have been looking into how I can incorporate some LED bars into the shape. But, then I went a bit further down the rabbit hole and figure that instead of using an LCD screen (which was 800x480 resolution in the above case) I have found that you can get 2mm pixel pitch LED screens which would be super cool for this I think. So I've found a screen that is 256mm across, and 128mm tall - which is a pretty damn good fit for the carina dash: (The circle indicates the visual block caused by the inside edge of the steering wheel, so outside of that is fairly useless space) Previously I was trying to emulate the sharp edged aesthetic of a fixed segment LCD display. However this will end up looking a bit more... Commodore 64 or something. haha. I'm not 100% sure if it will work out how I'd like, but it will be fun to play around with. There is already a really awesome library written for it, to run on a Teensy 4.0 which can render things crazily fast. One issue with the LCD screen I was previously using is that the refresh rate was fairly crap. Which is why you cant have things like a shift light/bar just represented on the screen. It's too slow. But these LED screens have an insanely fast refresh rate, no problem. So I can incorporate my shift lights directly onto the screen and it will be super fast. Here's a video to get the general idea:
- 76 replies
- 26
Looks like its a Melexis rotary position sensor. Too complex will adapt a regular tps on.
Bit of a mindfuck with my throttles. One bank has a 4 pin plug and normal voltage divider circuit. Second bank has 6 wires, and i assumed 2 separate 3 wire circuits. But nope, its got magnets & shit. Im thinking its hall effect but i have no idea how the wiring goes. Or if it would likely output a variable voltage or a frequency or whatever. Anyone (by which i mean @h4nd ) have any idea?
Yeah that would be interesting to see, especially with a surface mount thermistor on the runners. Because the metal throttles on mine would get icy cold.
Yeah I'm not going to run outboard injectors. But always interesting to hear some other perspectives if he's keen to yarn about it! It might be to do with that when you slam throttles shut, then it generates vacuum. So it lowers the boiling point of fuel so it clears off all of the residual fuel on the walls pretty quickly. But if it's ahead of the throttles, it just sits there. I ran the echo with fuel rail mounted ahead of the trumpets, and surprisingly it idled absolutely fine. At full throttle the fuel map didnt even need any adjustments either. But transient throttle was really gross, and I dont know if there's any good way to make that better. There werent any apparent benefits from it though, car wasnt any quicker. I still think the only good reasons for outboard injection is for engines that have poor mixing inside the cylinder (Super short stroke) so they need to premix it more in the intake. Which is why some engines seem to get gains from it, others dont. Because you're only "gaining" what a longer stroke motor achieves inside the cylinder anyway.
My loom is mostly finished. Will give it a few tweaks to make it look tidier but happy with how its turned out. I still need to plug it all in and verify that everything works / wired to the correct place / etc. Which takes some time. I've got two more plugs to do, that tie into the body loom and my fusebox arrangement. So I need to try remember how all of that works. I've given up on finding e-throttle plugs, so I just slotted some terminals onto the pins inside. Filled up the plugs with liquid plastic from the 3d print pen. Then heat shrink over the top, and silicone in the end. Feels nice and secure, hopefully works good. Will probably do the same with the 2nd TPS that I cant find a plug for.
- 76 replies
- 32
Yeah lots of interesting things in those pics. I wonder if thats just lighter or more reliable than a bucket setup?
Hey, thanks for following up! I cant remember the exact details or where I saw it. But I remember someone put a car on the dyno where they could hold the load steady. So they ran a butterfly throttle setup, then took the butterflies out and reran for zero difference (just controlling engine speed with dyno) Like has been evident from a lot of KPRs testing, there seems to be littler harm in just oversizing the intake diameter. Seems like the intake is most sensitive to changes at both ends (and length) but not much of the middle area seems to make too much difference, within reason. However - Barrels are still cool, nice and compact, and potentially easy enough to manufacture for a one off experiment. I found the picture of the barrel setup in the V8 race engine.
- 652 replies
Roman replied to yoeddynz's topic in Project Discussion
I came for the motor updates, but stayed for the MSpaint diagram -
True, but Al's mum does this 4 times a week. Yeah I am now convinced that a lot of companies like ARP simply buy a factory head bolt, then remake it as a stud without any testing. With the 1NZFE (sorry to pollute with Toyota chat) if you buy the ARP head stud kit. Then the VVT solenoid doesnt fit anymore, and it breaks off the end of one of your fucken cams when you torque it up. Have heard similar reports from some other engines. This is an awesome build. It's awesome to see some RFB stuff done properly.
- 44 replies
