sheepers
Moderators
Everything posted by sheepers
  1. Also I made this. It's a corner shelf for the shower. Currently there is a tiny shelf thing which is worse than useless and gets drenched whenever the shower gets used to soap gets turned to mush very quickly. It's made it is some bits of ali angle and chanel I had.
  2. Was driving home from work yesterday and I came slowly coating to a stop at a red light. As I was sitting there the car stalled as the light went green and I went to take off. Weird, cranking resulted in what was obviously something wrong, it was cranking with a weird rhythm and wouldn't start. So me and the wife towed it the 4ks home and I started trying to figure it out. End result is that somehow the cam belt jumped a couple of teeth. Like how the fuck did it do that? Seriously it was idling, nothing looks wrong but the tensioner does feel a little weird when I compress it and release it. Is not like any of these parts are old. Fucked if I know, anywho I might as well put a new belt and tensioner in it. I don't actually know if this engine is an interference motor or not, obvs stock jen one UZ aren't but this has kelford SC cams in it and I can't remember if they make it interference or not. I didn't hear anything at the time but the radio was on and from past experience when the pistons just kiss the valves they don't actually make a lot of noise. I'll get new parts, put it back together and do a compression test I suppose.
  3. who's this camel guy? ^^^^
  4. Simply add 4 cubes of garden mulch and hey presto! Raisedish garden bed.
  5. So, thinking about it I can do cam angle really easily. There is a hole in the side of the block and just inside that hole is a shaft that spins exactly half the speed of the crank for some reason. I can attach some sort of "trigger" to that shaft and a pick up of some sort to "see" that "trigger". The crank however might be a bit more difficult. And it goes without saying that i want to hide it so its not obvious
  6. Did a bit more. Pistons in and rotating assembly all together. Spins freely which is a plus. Went to put the lay shaft in and things went wrong. Front bearing was to small. It was size for size which wasn't going to fly. So with the aid of some CNC (completely not in control) machining I opened the bearing ID up to the correct size. All gravy. I need to figure out how I'm going to make a crank angle sensor happen as well as cam too at some point. Unno how to do that tbh, do i even need both? Do you still need both to run sequential injection and ignition? Fuck i dunno these days. anywho, I'm piecing the garbage back together.
  7. I built a retaining wall so we can back full it with dirt and make raised vegetable garden. Is 9.5m long and 400 high. I buried the posts 400 deep and rammed the back fill into the holes around the posts with a sledge hammer. Fucking tell you what, the rammed earth round the post is like setting the bastard in concrete. Missing image - topsoil. Yet to come.
  8. na, its a 7m block. i had to machine the nose of the 7m crank to get the 5m cam drive to work but the bottom end is all 7m.
  9. the hive mind decided that I should use the squirters, so in they went. Then I put in the crank and torqued it all up. It still spins which is a bonus. I also got all the pistons and rings assembled. Turns out when you buy expensive pistons made for a specific size bore the rings come with the right gaps. I checked every single one and they're all perfect.
  10. It'll be sweet, just gonna fucking send it.
  11. Everyone's opinions are worthy my man.
  12. Oh and just to be clear the pistons should make it about 13 to 1 CR so it'll make a bit more heat at the top end.
  13. Na, I just wanted some other perspectives in case there as something in missing. Is not a turbo engine bit it should rev. And the pump should handle it fine, it's how it was from factory. I'm kind of leaning towards running them just because they're there and they'll more than likely work to fling a bit more oil at the gudgeon.
  14. Cheers for your thoughts. Funny story about the cranks I had. Basically I had two, one looked a bit worse for wear and one was excellent except number 4 main was a tiny bit scratched looking. So I set the better looking one up in the lathe to machine the nose to take the smaller drive pulley for the 5M and that's when I discovered the crank was bent. Which was what caused the engine to grenade in the first place. And that's why I ended up with all the broken 7M junk. So the "bad" looking crank was perfect and that's the one I used. And whoever built the 7m before me never checked the crank for runout. And I bet it would have been super tight to turn as well. Should have been spotted before building a whole engine but I guess not.
  15. Oil squirters. I need your opinions people. This being a 7M turbo block it has them but I don't think I need them. The pistons are basically 7M turbo pistons with a different dome so they have the transfer holes that stock 7M pistons have. But I dunno? I'm going to be running the larger flowing turbo oil pump but the question is, Should I run the squirters or not? Keen to hear your thoughts.
  16. I had to do a few little jobs if the celicas but now I'm back into this. Ended up getting the crank ground just because. I've been measuring Mains and big ends to check oil clearances etc. Surprisingly enough when everything is new and crank is ground/ block is line bored then everything is in spec. What comes as no surprise is that the China H beam rods are the thing with the widest variance and the closest to being out of spec. And as is fitting for such an engine a toilet brush was the perfect tool for washing the bores.
  17. Had to do some rust repairs for wof. Didn't realise how bad it had got, both sills behind the doors needed work. Is a common rust area for celicas, side window dumps shit down the quarter and it's sort of double skinned at the bottom. Anywho, drivers side needed a whole new inner and outer sill made and passenger just had two small holes so I welded them up. Side note, I thought I had already been in to the sill in the past but it turns out it was all original. So it had lasted 47 years which isn't to bad. I fucked up the clear on the drivers side and got some runs in it but you can't really see it. Also I did a pretty good job of flicking in the new colour over the top of the old. She's pretty hard to fade metallics but this time I did alright.
  18. how are you sizing the baffles? my understanding was that they had to be equidistant from the speaker edge all round and a whole bunch bigger than what you've got there?
  19. I needed all the length I could get. The desk is for both of us to work at so it needs to be as long as it can. I cut the slabs at the longest I could fit in the van and that dictated what lengths I had to work with.
  20. That's Rhona's handy work. Not sure why she decided she needed to do that tbh
  21. So 2 and a half years later. Where the fuck did that go? Its been driven and moved from place to place while I built things at the old house and now we're in new house. Got a warrant for it the other day. The guy said the rear lower control arm bushes looked borderline, so I wasn't going to leave it like that and I got some new ones. Thing is these bushes have always worn out faster than any of the other ones, they've always been a mega cunt to install and they always looked like they were the wrong ones. Today, 13 odd years after I built this thing, I figured out why. I had left the steel sleeves from the factory rubber bushes in the arms. No Fucking WONDER!! funny how you can do shit wrong on multiple occasions and not even see it. I made a tool to push out the old sleeves and low and behold the new bushes fit a zillion times better, almost like they were made for it. I am still 1000% going to fully rebuild this car, every nut and bolt, but I need to build a workshop first so once again this car has to wait.
  22. Desk is finished and I'm pretty stoked with it.
  23. I made a table/ desk out of a couple of slabs of Norfolk pine. Planed about 15mm off the faces and sanded it. First with the belt sander then up to 240 with the orbital. I've just put the first coat of Danish oil on it Haven't done the legs yet, I'll take them off and do them in a more back friendly position.
  24. I bet you'd forgotten about this. I certainly did. Literally. The machine shop rang me up and asked me if I was going to come and pick up this block. I didn't know what they were talking about. in amongst building room on the old house, selling house, buying new house and moving house I actually forgot about this engine. But here it is, like a bad smell it just keeps hanging around. So the block has been cleaned, main journals line bored, cylinders bored 0.50 over and decked. I've got a new everything for the bottom end and I'll put all that together. Cylinder head is being worked on. Is getting 1mm over size valves, shortend valve guides and the valve seal spigot is being machined to accommodate the bigger cam lift. New cams as mentioned new springs and all that. but that's to come.
