keltik
Everything posted by keltik
  1. Test run this morning gave some good data. At 3600rpm cruise, oil temp rose to a steady 120c. I originally placed the cooler on the manual temp control line so it only saw a medium amount of water flow at whatever temperature the engine block was at. This wasn't ideal. I did another run with the manual temp control valve wide open so the oil cooler would see max water flow with a lower water inlet temp. The engine chilled down to 30c and the oil temp settled at 95c. So its clear I would need the oil cooler getting its water from somewhere else. Moved the cooler in line with one of the exhaust manifold cooling feeds. So now it gets feed water straight from the jet pump and sends its outlet into the drivers side exhaust manifold which has enough flow it shouldn't mind being fed warmer water. Final test will be a JBNZ run up the Tarawera river tomorrow. I did also find a new water leak from where the battery box plywood base rubs against the hull - its worn through the steel. The bottom is also looking very second hand so there's only 2 years left before it falls to bits I reckon.
  2. Had everything set for my oil cooler. A long ass M18 bolt with the hex parted off. A 12mm hole bored down the center and a nut lathed down to half width, Subaru oil cooler with a new seal. Began assembly and hit the first snag...I never measured the diameter of the sealing surface on the block side of the Subaru oil cooler housing. I just assumed it would be the same as the filter side... It isn't. So the inner recess is where the seal should sit and the outer protruding bit is the diameter of the oil filter housing sealing surface on the Holden block. Couldn't think of a better solution than to cut a new gasket to fit over the raised section and see if it will work. Bit of sealer on the jointing paper, fingers crossed and bolt it together eyeballing everything concentric. Fired it up, no leaks so far and about a 10psi drop across the cooler with thick cold oil. Im no fluid dynamicist but my intuition says this pressure drop will reduce with thinner hot oil? But then the flow rate would be increased through the bearings so I really don't know. Going to take it for a blast and see what happens. I would've been happier if the cooler fitted properly... But I'm also going to be happier if the oil temperaturev needle stays on the gauge.
  3. Worthless without the Dave and wreckers never include that
  4. Got a small oil cooler off a Subaru and all the gaskets to fit it. Should be able to put that together tomorrow. Tonight's job was to verify my oil pressure issue. The last couple trips I've been seeing 100+psi cold and 80 hot.... Which seems excessive, especially with my high oil temps. Oil temp bottom left, water temp bottom right and pressure top right: Grabbed a pressure gauge from work, replaced the factory pressure switch and took some readings: Meanwhile the dash gauge was showing 85. So I put another mechanical gauge in the same port the oil pressure sender was in: That seems rather conclusive. Gave it some big revs but still only saw a max of 75psi on the mechanical gauges. So hopefully tomorrow night I can install the oil cooler then see what difference it makes on Sundays river run.
  5. Custom strut top mounts for a vehicle with double wishbone suspension - how hard to get that certified?
  6. All the gubbins is glued and bead rolled / crimped together like a coke can. There is a crowd who do rebuilt ones for $1500 each but their reputation is shithouse in the Jag community - lots of early failures and dead ones out of the box.
  7. Pulled the valve block and reservoir this morning. It sits under the spare tyre in a little foam igloo so it's pretty easy to get at. Of course everything was dry, free from corrosion and looked fine. I put some pressure into each port and nothing leaked noticeably. So I had another go at a ride height calibration.... Which failed as usual. Unable to complete the air up procedure. The car looked pretty level to me! Used the scan tool to get it to air all the struts to maximum height and then I found it. At normal ride height, it doesn't leak. But as soon as you get any droop on that corner - whoosh. The system doesn't have a ride height sensor on the driver's front, it just uses the passenger side and looks at the pressure difference between them. Anyways, its decision time. The passengers front strut started leaking a few months ago so I threw in a second hand one which ended up having a good air section but the shock is mega soggy. Do I; A) Replace both front air struts with new Jaguar/Bilstein ones. Everything will work, probably won't get change from $4k. B ) Replace both fronts with Arnott ones, they delete the active damping (which I quite like). Closer to $2.5k. C) Convert to Jaguar S-Type R coilover struts. Maybe $3k with some modified or custom front strut tops....assuming I can still find the parts D) Use the Arnott Eibach coilover conversion kit. Worse ride, no adjustable height or damping, higher ride height than I'd like. It's the simplest conversion to do where everything will bolt in and play nicely. Probably $2.5k E) Roll the dice on a pair of second hand struts and see how far they go. Most people online seem to think the adaptive damping isnt worth saving but I think they've never driven the car in a way to make it work - its pretty noticeable when you start throwing the steering wheel around.
  8. More diagnosing and I was pretty sure the exhaust valve or compressor was the fault. Managed to remove the compressor in half hour, easier than expected. Dismantled it on the bench and found absolutely nothing wrong with any of it. Piston rings looked good, the exhaust valve assembly was clean with the right resistance on the solenoid. All the check valves work. Stuck it all back together and commanded all struts and the reservoir to air down. Starting from there, it pumped everything up to pressure in a normal amount of time. About 3 minutes to get the car leveled and fill the reservoir to 200psi. Watched the live ecu data as it was doing it's thing and everything appeared to make sense. Then it threw the suspension fault light again. So now I have absolutely no fucking clue what could be wrong. Tomorrow I'll try recalibrate the ride height sensors and have a play with the valve block.
  9. Done some diagnosing today. I'm putting my money on either the compressor exhaust valve sticking or the main valve block. All ride height sensors read normal and the only pressure sensor is showing sensible numbers. Couldn't find any air leaks. The only way for air to leave the system is through the exhaust valve at the compressor. If it sticks open, the compressor can't air up the reservoir tank and whenever a strut valve is open, the ride height decreases as the air goes out the open exhaust valve - even with the reservoir valve open. So the system gets confused, throws a plausibility error and shuts everything down. Looking at the live pressure data while driving, this all seems to add up. Next problem is the exhaust valve is part of the compressor assembly. So I might spring for a new one.
  10. Hmmm "air suspension fault" on the dash, all shocks on full hard and no ride height corrections happening. "Leveling plausibility error" isn't very descriptive but usually seems to mean an air leak between the compressor and reservoir or a tired compressor. Couldn't see any leaks at the reservoir or valve block so time to remove the front guard liner and have a look at the compressor, if I can't see any leaks I'll throw a piston seal kit at it. And will continue to ignore the cat efficiency faults
  11. And here's where I'll list the problems I'm currently trying to solve. 1) Depth sounder and speed log don't work. Tempted to bin them both and install a fishfinder chartplotter combo. 2) The previous owner has been a little liberal with his painting so I need to figure out the best way to remove epoxy paint from stainless steel hardware. 3) The trailer leaf spring rocker can rotate too far as the mounting bracket used isn't right for it. This causes the rear leaf spring to fall out of the slipper at high amounts of articulation like when going into my driveway 4) The tyres are perished to hell and the rims ain't looking very roadworthy. So I'm tossing up whether to swap hubs and convert to 4x100 which I have lots of spare wheels for (and all my other trailers use) or do I just buy new tires and rims to suit the 5x4-1/2 pcd. 5) The outboard gear case is leaking oil through the propshaft seal. Should be an easy fix... But the tilt mechanism is seized solid and looks like it's going to be a mission to free it up. 6) The on board electrics are shit, need some deep cycle batteries and a small solar charging setup. Not sure about how to properly vent the batteries when they will be under the seats in the cabin.
  12. First problem encountered was where to park it... On the driveway will do for now but I might be able to fit it down the opposite side of the house once I get a couple trees removed. The interior is pretty bare but everything needed for sailing seems to work and I haven't found any structural issues yet. Managed to get it out sailing on lake Rotoiti the day after I got it home.
  13. Posting a thread here because access to the oldschool hive mind is pretty helpful. I've got plans to charter a yacht and go sailing around Greece for a month in 2024. Partly as a throwback to the family sailing holidays I had as a kid, partly as one big adventure with my dad before hes too old to want to do it again and partly as a way to get married in style. To accomplish this, I need either a RYA Dayskipper or Yacht master certificate... Or an international certificate of competency. To get the ICC, you basically do a theory exam on navigation and rules, radio exam with a DSC VHF then a practical exam handling a sailboat for a variety of exercises. Dad's already way overqualified but I can't share a boat with him or one of us won't make it back alive. Probably me tbh, he's pretty fit Chartering a boat in NZ is ludicrously expensive so getting some practice for the exam was going to be a challenge. So I bought a boat. Poor wizard nearly had a hernia dragging this thing over the Napier-Taupo. From what I know, it's a Ross 780 built sometime in the 90s. The hull is glass over wood. The Ross was a pretty popular trailer sailer designed for a good balance of racing performance and cruising ability. The other boat I looked at was an Elliot 780 which is more racing oriented. This one was a project boat needing some love, so the previous owner has painted most of it and started on the repairs... I don't plan on a full restoration - just gonna make it suit my needs. If I can kit it out to be able to spend a few days pesting around lake Taupo or tow it up to bay of islands, I'll be happy.
  14. Wouldn't the smaller valves do less damage to your piston?
  15. Would anyone like to purchase my accommodations with j5 in gizzy and te araroa? I think I just sold my last motorcycle
  16. I haven't. I'd rather be unpleasantly surprised on the day
  17. If the Bergman is a complete cunt on the gravel, I might join you.
  18. The regular v8 is lower spec and they made more of them. There's a reason $160,000 fell off the price tag. Still a reliable car compared to a BMW.
  19. Forgot to mention I bought this thing from a dealer and got a 1 year 'Protecta' mechanical warranty thrown in. From the warranty booklet: Suspension air bags, shock absorbers, rubber components that have failed due to wear or degradation and catalytic converters are specifically excluded. But I did manage to claim for the instrument cluster repair when the speedometer stopped working. So a $900 job only cost me the claim excess of $395. None of this surprises me as I have weekly phone calls with these warranty companies about customers vehicles... But everyone seems to be shocked and offended when they find out how little is actually covered. So let this be a lesson. Read the exclusions, actually fuck it - read everything. Owners manual, insurance policy wording, anything you are buying or signing.
  20. Things I'd like to do: 1) Convert the interior to a nicer color. Mine is 90s nicotine stained sun yellowed plastic. Or 'Sand' as Jaguar called it. Id like to change it to grey or ivory white. Also would love a heated wood grain wheel. So to accomplish this, I plan on buying an XJ8 which is cheaper and swapping the interiors, then selling the donor car on. 2) Either get the centre display screen modified to run Android with a 'Jagdroid' conversion or add an Arduino Bluetooth module into the existing minidisc player which will allow the steering wheel controls to skip tracks. 3) Sort out the exhaust so it makes a tiny bit more noise but not too much. 4) Aftermarket intake pipe to delete the silencer on it and get a smidge more supercharger noise. 5) Supercharger pulley 6) LSD
  21. Just making a thread in here so I can post some crap and get feedback. I've had the car a year now and still don't want to sell it so I think it's officially out of probation. Here's a quick run down of things that have gone wrong so far: 1) All 4 door speakers died due to the original glue used in manufacture dissolving the copper wires to the voice coils. Since they are reasonably nice Alpine speakers, I repaired them. 2) The front tyres were rather lumpy. 255/35R20s don't have much give so I think the previous owner smashed them into some potholes causing them to delaminate. 3) Trans cooler pipes have started weeping oil from a crimp. Looks like a total pain in the ass to replace so I'm ignoring it for now. 4) Engine oil pan also weeping a bit. See above note. 5) Engine light is constantly on for both banks catalyst efficiency. 6) The front left air shock developed a leak requiring a complete replacement as the air bags are all crimped together and not serviceable. 7) There's a bizarre rattle from somewhere in the front subframe that I can't locate. 8 ) Im not sure why but there's more engine noise when turning than driving straight. Mounts perhaps? Anyways, these cars are regarded as being pretty reliable except for the air shocks. At somewhere between 2-3k per shock, I'm not looking forward to buying more of them. It does look good at max slam but I wouldn't want to drive it on or near the bump stops as they are inside the shocks... and the top hat seals would probably not like it. To balance out the problems, I'll share a few good points: 1) Fairly comfy ride, I'd give it an 8/10 overall or 10/10 comparing to anything else you'd buy for this money. 2) Reasonably fast thanks to it's relatively light weight. The whole body is aluminium and I think it weighs about the same as a Subaru Legacy. 3) Having big comfy armchairs with adjustable reach pedals and steering makes it very comfy for my lanky frame to drive long distance. 4) OK on fuel, I get a consistent 10.5l/100km when the bulk of my driving is open road 100kph. 5) Very quiet cabin with lots of insulation and double glazing. I don't get irritated by road noise on our shit roads. I've got a few projects to do on this thing so hopefully some people here can share advice.
  22. You're going to miss two unfit sad old men trying to wrestle 200kg scooters over the motu I'm not sure how you plan to beat that
  23. Jaguar S-Type and XJR, Audi R8, a few VW models with Brembo brake upgrades. Trailer caliper is probably cheaper
  24. A few mid 2000s euro things had a separate cable actuated caliper on the rear discs for handbrake duty. Could maybe repurpose one of those?
  25. The torque pro app has been pretty good for me. Got 3 or 4 Chinese obd adaptors and usually one of them will work... But not always the same one
