Everything posted by fuel
help: need cam seal (and some other bits and pieces)
fuel replied to CylinderHead's topic in Tech Talk
Yeah I wouldn't go to supercheap either, our new parts system software somehow has fucked our our cambelt pricing, most have nearly doubled in price. Try Segedin's in AKL (http://www.staparts.co.nz) or as suggested like Partmaster or Appco. Partmaster do have a huge mark-up like Repco/Supercheap do when it comes to retail pricing as well, but most good cunts will give you trade price or at least loyalty discount. -
Holy incredible update batman! Have been neglecting the rolla hard - eterna taking all my time, but I've managed to squeeze in some work on it:
or on my jeans but not just any jeans - my parts list front pocket jeans!!
There's a few people on Austarion who have done this, one of which has had this setup for three years running reliably. The main problem is with the VR-4/Evo block as it has equal size water jackets around the front and rear of the head, whereas the Starion block (as the original thermostat housing is at the front of the head anyway) has smaller jackets at the front, and larger jackets at the rear to promote more flow through the rear of the head first. I will be placing the water temp sensors at the back of the head where the original housing would have been which would show if it started overheating anyway.
If you can get the part numbers for the bushes you need/want (see website above) come see me and I can order them in for you from aus. Our catalogue is shit so wont list crowns of that age
Fuck so wanna go, but I don't think I can get off work at such short notice plus I really need the money
Hey Dan cheers for that info, I'm planning on doing the DOHC conversion to my Eterna at the end of the year. I'm just going to use the original (Starion) bottom end, with VR-4 crank/front oil pump casing, Evo III rods and pistons (higher compression than VR-4) and RVR head with Evo III cams. I'm still unsure what to do about the water pump, power steering pump and air con pumps. I'm guessing your EX doesn't have PS or AC so you didn't bother about them. As for the thermostat housing, alot of the Austarion guys make up a blanking plate for the rear of the head and relocate the housing to the front, but it requires modification to the head gasket to allow more flow to the rear of the head.
Yeah even my king springs aren't quite captive in the strut of my Eterna. Best solution is to shorten the shocks then you can run shorter springs
Also when lowering it (drastically), the camber will change from positive to negative which helps bring the top of the wheel inside the guard.
Oh what a night....
I'm keen as a bean but am going to a workmates farewell dinner tonight first
Oooh that reminds me I have a blanking plate to suit a 4G32/37 too. Find a carby turbo cordia electric fuel pump or any other inline low pressure pump and you'll be sorted.
Yeah, and make sure you use the spacer too which should come with the new pump. If you don't install the spacer you can damage the pump also.
I just remove the dizzy cause I find it easier to get to. But that was in a FWD Galant with the pump being at the rear of the engine bay, whereas your RWD cars are a bit easier access wise. Cam -> Is that on your 4G36 or 4G63? If 4G63 it's in a different place than the 4G32.
The distributor shaft has a mark to line up with the distributor body. As long as these are lined up when number #1 piston is at TDC you'll be fine. Takes a bit of fiddling though, as when you insert the dizzy the shaft will twist a bit, so line up the marks and take note where the dizzy rotor is pointing, then move the rotor in the opposite way it turns before you re-insert it, basically compensating for it moving when you insert it. Check the rotor is pointing the way it should be.
You gotta have number #2 piston at TDC in order for the lobe on the cam to be at the lowest point, installing the pump when not at #2 TDC could cause issues.
Yeah they usually have quite a large spring on it so will be initially hard to move. You can move it a few mm from memory before it starts to get hard to move. Hang on to your receipt as the experience me and Pete have had with those pumps is they don't last long. *edit* oh yeah don't forget to read the instructions carefully. If you don't install it exactly right the arm can slip off the cam and then it can snap when the engine turns over. You'll have to remove the distributor to get to the fuel pump too, so make sure you are familiar with setting the timing on the 4G32.
Supercheap wont have any mounts in store, and not likely they will be able to get any in either. They do mainly OEM replacement stuff as opposed to off the shelf universal type etc
Hey nice was wondering if someone would snap that up. Is it a genuine widebody or does it just have fibreglass guards etc? I don't particularly like the flares though.
Haha fuck you guys are rofls
Well for starters it's a G63B engine, not a G36B. Aka the 4G63. I have a PDF Mitsubishi manual for the SOHC 4G63 in the E33A Galant, most torque settings and clearances will be the same for the Starion turbo engine. Send me a PM if you want it e-mailed to you.
To OTP or not to OTP, that is the question???!!!
fuel replied to Camel's topic in Upper North Island Region
How did this go? So wanted to come up but have been chronically sick these last few days. -
You the same guy whose been having probs with veering to one side while braking on trademe? I recognise those bright red calipers from there
4G92 will be able to rev out more sure, but probably wouldn't have the same torque delivery as the 2L. Wouldn't be too much more of a cunt to convert to RWD than the AMG engine. Stick to the AMG engine, just don't expect it to be a really high revving screamer.
Find a MIVEC 6A12, 200hp standard from a 2L and rev beyond 8000rpm easily. Not to mention they sound awesome when howling away at that revs. In my opinion the AMG 4G63 probably wouldn't be able to rev beyond 8500rpm easily without serious money thrown towards it. Even if the head setup is really excellent remember the bottom end is still much the same as your SOHC jobbie. The MIVEC 4G92 etc has a much better bore/stroke and rod/stroke combination to allow it to rev to 8200rpm safely. You are probably familiar with the size (ie the chunkyness) of the rods, crank etc of the 4G63 - compare that to the 6A12 or 4G92 and you'll see why they opted for smaller (and more lightweight) rods.
