CaMpylobacter
Everything posted by CaMpylobacter
  1. i dig the 6's as well, but hey, same chassis as mine 6 series = 5 series - 2 doors + mega rust
  2. when I'm driving it, yes hahaha pwnd sparkle
  3. put a rotor in it, chromes, springs out.... OR - do somethin different with it, as you are
  4. werd, lucas headlight switches are "dim, flicker, off" at the best of times - good to hear you've got it fixed.... now 1275 it
  5. heel toe my friend...... or neutral & left foot braking.. simple
  6. carbs vs efi on a gze??my god.... it's noteven that hard to wire!!!
  7. And what just happened to the budget? That adaptor kit is interesting but still pricey and then could cause radiator clearance probs in a Starlet. Modding the firewall is cheap, easy and legal if you check with your certifier first. Callum the adaptor kit wasnt actually very expensive at all. I doubt this dude would be keen on a 20v anyways....
  8. use teh 4agze crank angle sensor type "dizzy" and aftermarket ecu, or, as i saw on toyspeed a wee while ago, an adaptor kit to drive the dizzy off the cam pulleys... on '86s you dont need to cut the firewall, if you use the gze bit, so really, you shouldnt have to on a starlet either.... not 100% though
  9. you shouldnt have to, at all, if it's mounted properly. rwd manifold isn;'t essential , i wouldn't pay $300-400 like some guys are chargin these days, just get a fwd altered.... easy
  10. CaMpylobacter
    TE gemini
    4ze1 partial engine = List 4270.17 Trade Wsle 3882.01 Head = List 1747.26 Trade Wsle 1397.81 brand spankin' new would need manifolds etc, but yeah, seems a cheap engine, shouldn't be hard to get a decent one, even if you needed to rebuild it or something........ rodeo's are everywhere in teh wrckers, i guess, as all utes etc are, it'd be fairly high k's though
  11. mates dad has a harley in his lounge for an engine job-takes up pretty much the whole room.... says its better than doin it in his shed lol
  12. can't be - 7 digits in that plate champ vr4 engines are better than evo3 anyways, stronger from what I hear
  13. gotta be under the dash somewhere -try arond the steering column area.....
  14. fuses are in the little box on the fire wall, just to the right (car's right) of the carb, toward top of firewall...... any wires fallen off the main power feed at the solenoid??? down the bottom of the engine bay, RHS next to the engine...... hah, I never really had electrical problems on any of mine... sorry dude.
  15. 4D52 dude - diesel.... thats what I;m told anyways..... google is yuor friend oviously, to delve into it further.
  16. hydraulic, although you wouldnt be able to use it due to the column change aspect.... l200s with 4d52's in them are common as mud, shouldbnt be hard to get a gearbox at all..... turbo or not,m they should be the same. you wouylda heard it from me a couple years back when i was looking at that van that rob from 1st automotive had as a workshop hack - bert at mike murphy has it now... mean bit of gear, would be the first one done in nz i would expect, it's been around for at least 4 years. rob told me that all you need is a 2.5 turbo box, and he used an evo 5 flywheel and clutch assy. again, the non turbo box is probably the same, might have different ratios or something - mine does 3200rpm at 100, not sure on the diff ratio though
  17. log in pus nuts....... turn's on, why dont 4g63BT's from vr4's bolt up? apparently 2.5 turbo diesel boxes are the ones to use in vans, should be easy as pie to get an l200 box so you have floor change, then mac a vr4 engine in front of that.. easy. water pipes are next hardest part, which shouldnt be too bad
  18. check the switch too - lucas headlight switches = dim, flicker, and off.... if you need anything give me a PM, prolly got most bits you'll need
  19. there's two types of retops - big port (high comp bluetop essentially) and small port- small port is 100kw. you can turb's a 4AG easier.. plus they go better turb'd - can get some mean numbers, even out of a blue top with stock comp - 15psi is do-able on stock ecu. No better bang for your buck than a 4AG in a KE... easy horsepower to be had. mega buy a GZE, ditch the charger, they're shit.... run a t28 or something on there.. will be awesome. with a turbo running 5psi on a 4agze, you'll get better power thn the supercharger running it's stock 8psi. and 300hp on a turb'd 4agze isn't that difficult
  20. go for teh 4ag, 3hp more (bluetop vs. 2tg, of coruse the red top etc would be better again) and like 25kg lighter apparently... 4ag = more parts available blah blah blah IMO - small port redtop 4age, or silvertop 20v... retro-tech it up.. (blatant pwnage from RT )
  21. austin princess ap 4 pots should bolt straight on - just cant use backing plates??? and have to slpice the brake line into 2 (each caliper has 2 lines, instead of one like the escort calipers) pads just overlap a bit but thats no problem theres heaps of princess' shat out all over the place. mat picked some calipers up for $25 from this old cunt in feilding.
  22. split case y0... stock ae86 fitment aren't as strong as steel case. they don't like quick changes (second one-sychros were a tad, umm, welded...) or clutch kick.... was told they were "bullet proof" stock 4age with extractors and standard exhaust.... go figure
  23. I wouldnt got to the effort of a T50 unless it's a bolt in job.. and try and find a steel case one if possible.. t50s arent that strong, I killed two with a standard 4AGE.. although I was a tad rough on them..... still, W55 pwns
