been looking in 1g engine manual and under touruble shooting/engine hesitates/poor acceleration one of the possible causes is this
"emission control system problem when cold engine(1g-e engine only). Remedy check spark control system"
anyone got any ideas what theyre talkin about
how can i check to see if cold start injector is leaking? isnt really to hard to start and idles fine. just bogs down when i take off and its only in cold temp. will check the other things. has no o2 sensor as its 1ge nz new. have a compression tester so will test that this weekend, cars done 160tho ks
also check tension of alternator belt if its too loose itll explain why its making noise and not charging properly, if its good then yeah itll be alternator, had this problem recently
so ive tested my switch, getting 35 cold and 75 hot which is within spec(below 10 degrees 30-50 and above 25degrees 70-90). so next i guess is so test the injector
put some fender mirrors on this today. hoping the have the top half of car resprayed in the next month, just the dark green as its rubbed through the paint in a few spots
if you could man that would be awesome/ dont suppose you wanna sell it? dont have internet at home at the moment so makes shit hard
will try running 12v to cold start this weekend, problem is theres only a short gap to try sort it before it gets up to temp
So about a week Ago the 1g in my gx60 started running shit when it's cold. Was fine up until then.
Have since replaced leads and plugs which did not help. Fuel filter was replaced about a month Ago and made trip from Welly to chch no problems.
Anyone get any ideas as to what it could be?
Is only when it's cold. Starts fine but when ya put ya foot down in bogs out
my only other lead on springs has fallen though, is noone able to stop by zebra for me? theyre easy as to get out, just un bolt the bottom of the rear shocks and pull em out so literially 1 bolt per side
