Posts posted by Carsnz123
Bit of productivity has happened while being off work
Chainsawed my way into the woods to get bits from the parts car.
And retrieved some upgrade parts.
Then went on a spanner hunt
Now the car has power steering. Was a massive ass to park and drive at slow speed. Best part is no leaks or whiny pump. Had to get creative with the tensioner as the belt i had was a touch too long. Ill get a new belt and change the tensioner when things are open again. For some fucked up reason it Didn't want to start when I went to test it. Even after swapping to a better charged battery. fired a bit of brake clean in the intake in lue of engine start. It finally caught with some horrific knocking noises but then purred. I know the starter is getting tired so my guess is Its drawing so much current that the voltage going to the cutoff solenoid is too low and its killing the fuel. Another thing to fix. Also loosely fitted a china click clack fuel pump to help the built in lift pump. The factory diesel cars use 5/16 hard line to the tank. This being originally 1.8 petrol only has 1/4. It seams to starve of fuel under full load. Problem goes away with extra pumpage. When I can buy things I think ill make a 3/8 hard line for future-proofing.
Oh and I got some new wheels. Well I got them a year ago but have only just gotten around to getting tyres fitted. And Yes I attacked the decals with a caramel wheel because they were falling off and looking even worse. Will tidy up the paint and add new pinstripes along the body line.
That pretty well brings things up to date. See you in another 18 months.
13
The rear shocks failed a wof which was a massive ass seeing as the rear shocks are NLA and I needed them to be shorter with the slight lowering of the car. Ended up getting Vanette shocks and had a friend tig the top eyes of the old shocks onto the new ones. Also bought some lush mustard colored wool carpet and fitted out the rear with new carpet to reduce some road noise. I took it for a trip to Blenheim and back with a trailer on and wondered why the fuck it was so slow (even more than normal) turned out the front hoses were holding pressure in the brakes and causing them to drag. New set of hoses mostly solved the issue but Id say the pistons are a little sticky in the seals. I've pretty well replaced all the coolant hoses now. the first time it dumped it coolant I'd just gotten home. second time it let go just as I left home and I didn't notice until 10 min later when the tmp gauge pegged at full. I've done other things but can't remember/dont have pics. Here are some tow mission pics
Skyline to the rescue when the fuel pump failed.
Load was probably more than what the car weighed
This was a tad iffy in the wet
Using works resources to fix the Crown
Then using the Skyline's weight to help run the new engine in
Off to surgery
12
So I still have this and quietly work away at it from time to time. During the Hanmer trip in 2018 it missfired quite a lot and was really only running on 4-5 cylinders (sometimes 6 but rarely). The Injector pump packed up fully a week later. I sent the IP away to get rebuilt and got it back a few days before Christmas 2018 along with a new timing belt and tensioner. The seals in the IP were old, hard, and not working like they used to. Also spent time painting the door frames, Fitting a 3.7:1 diff, removing rust, and resealing the Jurassic Park windows. like usual I was a bit lazy with the pics.
8
Yes they are an F series (or interchangeable enough) The A on the end means they are open.
B would indicate a torsion LSD.
A03A is 4.1:1
A04A is 4.3:1
If you want LSD go flogg it out of an altezza. most of the manual 4 cylinder cars have a torsion unit in them.
According to wheel side data yes the townace is 4x114.3
On 11/04/2020 at 17:30, japawagons said:
What I've learnt in Racecars is if everyone tells you it's a bad idea, it's generally a good idea.
I apply this to many aspects of my life and it hasn't worked in my favor very often
I'm doing a similar swap into my GS126V except both engines are AFM rather than MAP. The conclusion I came too is that the single cam cars run a different body loom to the twin cam cars. I've resigned myself to the fact that it will require some cutting and splicing of looms to get power where it needs to go there is only a handful of wires that need either constant or switched power. All be it I haven't touched the car for a couple years. Too many projects.
This has some useful info if you haven't seen it already https://bluetwentyeight.wordpress.com/tech-docs/
On 24/09/2019 at 21:32, Geophy said:
Pity we dont have hills in Hamilton.
Lies. had to do a hill start on the steepest part of that slope near where @Truenotch lives... with a 2T trailer behind a late model Hilux.
/Also keen for icecream. need to find an icecream place close to work tomorrow.
Possibly get holes changed to suit slightly more common stem?
4
http://shop.ukrtrans.biz/wp-content/uploads/catalogs/A40.pdf
took a bit of finding but this is a manual i came across a while ago. The bloody MS112's trans is playing up so may have to delve into it at some stage.
For the 30s Rolls/Bentley engines we just used Morris running in oil. The run in procedure would be: take for decent drive with varying load. leave to cool down over night. Retorque head. repeat until gasket didn't squish any more. Change oil after 400kish. The rolls engines have a imperial fuck ton of 5/16 bsf studs to hold the head on which only get torqued to 18ftlb. Hence many retorques.
Currently running the Crowns 7M in after a ring/bearing job. Got lucas running in oil in it but fuck that shit is half as much again as penrite. Been for a run over the hills, Towed skyline home across town, and had a bit of thashing/skids at the hands of Harry. Currently driving to work and back. head will get retorque and oil changed at 400k. and probably another recheck of the head at 800k because M series.
The 3K which is next inline to be finished will be getting Penrite running in oil, drive up the tunnel road and back over dyres pass, and Probably a run to Akaroa to get a good run. retorque and oil change at 400k. just got to be careful of the cam as its been reground. K series aren't bad for picking up cam lobes though so should be fine.
I dry ring engines with a smear of assembly lube on the skirts of the pistons. Every other moving part gets a good dose of assembly lube as well as packing the oil pump with either vas or assembly lube.
Additional Barry fact: the center throttle layout was mainly due to a lack of space between the brake pedal and side of the body. Many left hook variants of the American cars we saw here in the 10s and 20s were conventional layout (clutch-brake-throttle).
Also be careful if you have to hone or bore the engine. I think these the deck surface is off square to the bores by 7 degrees. I could be wrong but I'm pretty sure its the 7 they did some sillyness on.
The basic formula is:
L20ET manifold
TD03 turbo
10 psi
wind fuel up
The L20ET manifold requires slotting of holes and a bit of port matching. The L28ET manifold doesn't without hogging a shit load of metal out of the head. No.6 does get hot with a turbo so an intercooler and clearing out your coolant passages would be a good idea. 10 psi is a safe level of boost and will give you more kick, decent fuel economy, and only reduce your engine life a bit. The fuel screw on your pump will need adjusting for more fuel but it will smoke like a train off boost. I have heard of people running 20psi but not sure how long engine lasted.
We've had a shit load of fun with @- i5oogt -'s LD28T Cedric but due to a crap cooling system its been overheated 1 too many times and the engine is a bit sick. So keep it at a normal operating temp and EGT below 650c and you should be sweet. But just remember you will shorten your engine life.
What side of CHCH are you on? I could come have a look after work one evening if you want.
Has "Invite only" show to keep it classy
Invites Ford Model As?
Bloody barrys
Actually got it running on it's carb tonight. 3.5 cylinders but close enough.
4
Finally got a spare moment to get pics on the interwebs
Whats disappeared is the front structure on the right side for the suspension mounts and engine
And holes where they shouldn't be. There is lots of rusty parts on the lower section but most of the stuff above the sills is pretty sound.
Hmmmm.... ill be back. got to measure a gap
9 hours ago, weetbixkid said:
Anyone know a good freight company to get an engine from wellington to Auckland?
What sort of engine? Trailer's pretty full but might be able ti squeeze a small bike engine in.
That KE36 rear wasn't very watertight off the top of my head. And being so low and having no suspension it was a bit of a shit to tow according @76rolla_gurl. Looked cool. Not sure where it is as both car and trailer have been sold.
@- i5oogt -s blardy honda. Next challenge. Attacking your OS car with a disc grinder. Bonus points for cutting CVs off from @jesselc.
8
@Avenga would you have a set of brake drums surplus to requirement? A friend needs some to upgrade the brakes on his model T Ford.
A middle age barry owns that. He started going on about how it doesn't seem to run right and maybe it doen't have the right plugs so I quietly walked off and left some other guy there listening. All it will need is a basic tune up. Few hours at the most. Amazing how far out of tune SU carbs go over a couple years.
FB says yes.
Lol. Saw that ad. I wonder how much grief thats causing VTNZ staff.
Old Lathes and machining shite
in General Car Chat
yes but its really spendy. Most likely would build it up and re grind it.
