Posts posted by vk327
Just now, spiderwebfx said:
TBH most of Jaycar's products are China spec items that have been branded. I've compared a few things from them and Aliexpress/Wish and they're identical but cost about 10x as much.
If you want Deutsch connectors, Repco can do the Narva ones, and can also get Hella ones. They're great but expensive.Jaycars auto electrical stuff can take a flying leap into the bin, genuine deutsch connectors are actually quite reasonably priced (given i do have wholesale prices from non retail suppliers) , just dont buy them from retail outlets like repco , for anyone interested I can price them up along with the budget home level proper 4 indent crimp tools
@Taistorm if you go the painless or similar route and need connectors & other bits for wiring, flick me a message, happy to help out OS guys with good prices for auto elect. parts
beware of chinese junk knock offs, they look similar but they cheap out on the terminals and end up with fuse holders & terminals melting from poor connection, stick to something known like the painless or the kruzin ones
- 6
On 25/03/2020 at 12:28, spanners said:
Been keeping busy while under the weather with the Coronavirus
Finally my summit order showed up. I’m a bit embarrassed that I didn’t realise Japrace in Chch sells the AN fittings for pretty much the same price. Won’t be shopping American again, especially with the exchange rate as it is. Had to go into japrace to do my panic shopping. Got a fuel pressure gauge and some hose and fittings.
Fuel line looks pretty tidy now. It’s -8 between the rails but only -6 from the pump. Just trying to save on fittings, the rails were -8 female.
for anyone doing an engine swap (with EFI) the Corvette FPR/filter is a great little number! Mine fits in place of original massive filter under the bmw. Cheap too. Saves running a return from the rails.
Started pulling bmw loom apart to see what I can biff. I want to retain a few sensors I think, so that dash works normally. Shouldn’t actually be too much of a mare. Will get commodore loom modified by someone way more special than me.Stocked up on piss for the apocalypse. I got fucking smashed last night on red wine and working from home today is not great.
I reckon this lockdown is going to be one of the best things ever for productivity on oldschool. Will certainly be helpful for me. Sadly I’m still working full time (we build/fix hydro power stations) but I’m sure I’ll manage to sneak out to the garage every now and then!
Stay safe out there cunts!
@spanners BMW wiring is so fun isin't it haha, iv got to do an e30 with an m54 swap soon, back to the topic of LS tho, Im assuming your using the factory LS ecu to run it, give me a shout if you want to get your ls loom sorted to standalone and ecu setup, its what I do as a sparetime job.
the 4l60e and vt ecu requires the speedo input to control the transmission shift points and also idle control on deceleration, without it you'll be stuck in limp mode, the sensor is a hall effect to the ecu, the ecu outputs a scaled pulse to drive the speedo, the 2 common ones iv used for conversions are the dakota unit and, the speedhut speed box (alternately could go speedhut electronic speedo or similar
brown wire is the alternator light. wire from ignition feed thru a diode thru a light and to the brown wire.
white is the alternator voltage sense, ideally wired to the battery + terminal (can be looped to the alternator + stud)
let me know if ya have any problems getting your standalone setup going, been a while since i done that one.
another option is something like this kit
use a sender and pickup unit fro a TB48 petrol safari / patrol, fit something like a walbro 255 or 465 depending on how much fuel you need
edit: may be easier to get a whole petrol tank and filler, the tank prob has a swirl pot for efi pump and petrol filler is different to diesel one
vn/vp auto & manual ecus are the same, just memcal programming varied, they are even the same between v6 and v8 trusty old delco 808. I do heaps of them for engine swap setup. VR series 1 loom and ecu will also run the vn engine.
On 01/12/2019 at 11:30, Ashkellybarr said:
Hoist question, I’m wanting to put one at mine but would need to be outdoor on slab like yours.
what did it cost you? You get a company to do all of it and sign it off?
dose the hoist need a cover or is it fine outside?
cheers
I done the concrete myself, im on swampy ground so has 5x 3.6m piles concreted in under the center area with a 200mm thickening and 200 thick ring beam footing around the edge of the pad, was almost 4 cube of concrete which worked out about $900, hoist is a motorex base model $2100 delivered,
So far been mint just keep it lubed well with spray grease, made a weather cover for the hydraulic pack and is all good
So after a few hours sleep after nightshift, got keen and stuck into pulling the sump since another new tool arrived the engine support beam made this way easier than having to pull the engine.
Got the k frame out, sump off, welded in a couple breather fittings and went to town with the rtv and new gaskets.
Pics tell the story better, also pic of how iv done the external 5/8" oil pickup in the sump.
Fingers crossed this sorts the leaks. Bring on drag day
no idea on 1/4 time but will be interesting to see, just needa get the oil leak sorted and should be good to go
Well back on the dyno at protune yesterday, made some good power (175rwkw 445nm at 11psi) but found an oil leak, seems like this car just dont like dynos haha, at least i was only cleaning up an oil puddle on the dyno and not engine pieces
Got home and checked it out, pulled the clutch dust cover...bonus its not the rear main rope seal.
Waiting on an engine support bar to arrive and il drop the sump clean it up Gonna weld in a couple of sump breathers and go to town with the rtv
Oh and all before drag day...
- 9
volts sound a bit high, will start to boil the battery at 15v, overcharging is just as bad if not worse than under charging (acid boils off hydrogen gas) should be around 13.8-14.2v sounds like the regulator on the alternator is failing
@Truenotch Im keen for caffeine & gasoline, gonna be heading up there anyway in the kingswood for hq muster
nov 24th is also the HQ holden muster at hampton downs, will be a busy day up there with caffeine & Gasoline on as well
VDO pump specs
VDO Universal Engine and Transmission, Differential Oil Pump
This small 12 volt pump is designed for pumping gearbox and/or differential oil.
It has also been used for pumping oil to motorcycles fitted with Turbos. Can be
used as an oil cooler circulation pump. Can also be used as a Turbo scavenge pump
for low mounted Turbos to better drain oil and avoid oil blowing through seals.Features & Sizes
- Voltage 12V ONLY
- 160 Litres Per Hour
- 4 Bar Pressure (58 PSI)
- 100 to 150 Degrees Celcius working Temperature
- 16.0mm Diameter Inlet
- 7.8mm Diameter Outlet (Straight) - 9.0mm Lip
- 127.0mm Overall Length- 1
VDO do a nice electric scavenge pump, will find the details and post it up
Had a rocker adjuster come loose sounding like an angry dwarf with a pickaxe stuck in the top end, easy enough fix didnt break anything and was just down the road from home. Decided to throw some more $$ in the because turbo bucket, brought a new 50mm wastegate to sort out the angry boost pixies, Booked for back on the dyno the week before drag day....
- 17
assuming its got the standard 25d4 lucas dizzy (like my old 73 had), you can buy off the shelf electronic conversions for the factory dizzy as they are the same internally as every other mini blmc etc 25d4 dizzy, nice and easy swap to ditch the points
Thanks, already got that one it dont show detailed enough assembly of the throttle valve and valve body, all the pieces fell out when we pulled it apart.
Hey All
got a broken 83 corona decorating my lawn at the moment, my mate brought it with a blown auto (previous owner rotated the rear tyres too rapidly).
we have replaced the burnt up clutch packs and steels in the trans, now have somehow stuffed up the valve body/ throttle valve and it drives but wont shift out of 1st. (it shifted before we took it apart)
anyone know their way around these transmissions or have a decent schematic of the valve body transmission is an Aisin warner 03-50 A40D 3 speed + O/D
pic of actual car, (may be for sale soon)
Cheers, was super happy with how it went, I had only driven it about 400km and dyno time (and about 10km on the replacement gearbox) before doing gumboot. will be good to see what it can do once i sort the wastegate out, the valiant do the whole run no problems?
@Shakotom And to think i had started work on a particular HZ ute... its a good thing I returned the HZ back to Chris and done this one instead
Wiring Harness Advice
in General Car Chat
Can do these for $70 inc grab steal and take(gst) and delivered to you, they come in 3 sizes for each of the DTM DT and DTP terminals
