Posts posted by BLIZZO
chur lads, bank account for patches is - 03-0830-0461287-002 just put your OS name as reference to keep things simple
After glen thats 11 patches left fags
sooooooooo i took the sweet sticker that VG / Mrs VG designed and have ordered embroided Patches. They are fully stitched 75x75mm glue backed patches with several colours on it.
I have ordered 30x pieces, 10x are already spoken for so the rest will be up here, first in first served
cost is $8 each, if they come in time ill post them out to some dweebs so ya can slam on ya vests for the ride.
tumeke.
heres a sneak peak
my baggage is strictly for purple Gs
- 7
Shit yea fucked roads sounds like good fun
So shakedown didn’t go so well. Aside from a flat rear tyre second gear has gone in this lifan 150, I’d say it either has worn dogs or a worn selector fork, either way I’m not pulling it apart as I just don’t have the time to get it sorted and then tested to be reliable. Last thing I wanted to do was pull apart the C50 to pull engine out as it likely won’t go back together ha, but it’s just an excuse to buy another 140 really.
When I got the puncture and waiting for sparkle to go grab his Ute I pretty much pulled the engine on the side of the road, finished the swap over a few beers last night, different CDIs and looms meant a bit of a re wire.
yx140 now installed. For some reason the lifan 150 blew the tail light and usd port, never had that problem with the trombone, thinking of adding a battery into this to smooth it out. Another test this arvo for 50km and it’s sorted, maybe a little rich spot mid throttle on the needle but it’s liveable. Just need to replace tail light and USB port and I’m good. Gets around 60-70 km per tank so I should be good for at least 120km with the fuel on me which should just suffice
st-90 is all officially finished, penny pinchers are off on a 120km back road pohangina valley pest tomorrow so I can give it a good shakedown. Turned out the flickering headlight (even at high revs) was a dodgy Chinese reg/rec, Ben had the same problem, as I got a batch of 4 and they must have all been shit, weird silver ones I haven’t seen before. Anyway sorted now, doesn’t flicker (only at idle it does obvs) and the USB charger works a treat. I think I will bang a little toggle switch on in the headlight bucket so i can turn the headlight on and off.
Fingers crossed nothing fucks out tomorrow, I already know I need to fix my poor mans scott chain Oiler / leaky output shaft seal
Wee test ride conpleteed on the ST. Headlight flickers like fuck, it’s astonishingly loud, like wear earplugs, feels sketchy as fuck to ride and I think the skinny 14” rear tyre will be ripped to shreds by the end of the ride.
im ready for east cape
- 9
10 minutes ago, 64valiant said:
Ahh yeah you where onto that pretty fast. Good score.
Yea was only 40 mins away in my old hometown of wangapooy, I actually knew the guy selling it. It’s a bit rougher than it looks in the photos but will tidy up alright. Can’t say no to a cheap CT
have been doing a bit here in there on the ST90 since finishing the CB50 for DGR last weekend. the wiring i did was rushed and hori as shit, and also took up all the room in the frame which ideally i wanted for storage (of like 1 can of beer lel). i also like the look of the stock aircleaner but cant use it as its way to small for this 150cc engine / carb doesnt line up with it or anything. so i gutted it out and turned it into a good space for everything electrical. this is ideal as if anything goes wrong in the electrical department its only 2 screws to open it and i can swap anything out.
i now have this space in the frame where i will likely make a little plastic container and hold tools / spares / maybe another little fuel bottle
also wanted to hold my phone for gps / filming purposes / wank factor and got this aliexpress ram mount rip off. very good quality actually, except the rubber balls arent as rubbery as my genuine ram mount. now i can pretend to me a 1200GS
- 5
also just grabbed one of these KTM tool kits of trademe, bloody cheap at $44 and has most things, will just add a few to it.
much more prepared this year
10 hours ago, Truenotch said:
I’ve also recently learned about how to set ignition timing with points, so I’ll set the timing right while I'm there.
grab a new set of points while your at it man, makes a huge difference, if you completely disassemble the points that are on it at the moment you will likely see some big pitting holes in the centre of the tungsten or whatever diamond spec hardness that shit is and will likely be slightly sharkstoothed as well. points are generally very cheap (sub $30) and are a consumable part that isnt replaces as often as they should. also condenser can cause missing and shit at high revs, unsure if yours is attached to the coil or the points, but probably another part thats worth replacing to get it running mint.
pretty sure the rsa would do a mega brain at 40 peeps, there wasnt even that many chairs. maybe ask them if we give them $400 bucks can they put on a marae spec feed of blood and guts for 40 people they might be able to organise it. im just gunna go with the flow, id say we will disperse pretty well when we get to hicks, but yea a phone call to tell the razza a few jims will be turning up wont be a bad idea
1 hour ago, Willdat? said:
I guess this is as good a place as any to ask. My CL50 is on exempt class B rego. I don't think it's going to fool anyone that it's a farmbike.
What can I do to get it back on full fee paying rego? It used to be registered as a 'power cycle' under the same frame and engine number (though a different plate!) Do I have to go through the MR2B process or can I just pay some $ to the post shop to change back?
is it registered as a "moped" on class B exempt, if so, you can just go to your local AA/VTNZ and do a class change. i recently did this to the wifes cx-7 as it was regod as a commerical vehicle as the dude did occasional uber driving.
if its registered as a motorcycle and you want to correctly register it as a moped i would think you would need to do an MR2B, but maybe not, id pop in and ask
so i have been smashing a few nights on this CB50 to get it ready for DGR and its finally sorted. I wanged the XL100 engine in it i got from @kdotlowe. the XL inlet manifold wouldnt work with the CB 50 so i made one up and had midge weld it for me
I also whacked the 3.25-17" nitto tyres i got on with some new tubes, they juuuuuust sneak in the front forks
Made up a new exhaust using the CB50 header which is suprisingly the same diameter as the xl100 header, but i wanted low pipe, and wanged an aliexpress megaphone type muffler on it as you can see below. this got it all going but it wouldnt run well past 3/4 throttle as it had a lean bog obviously from the uncorking of the inlet and the now pretty much straight though exhaust. tried playing with the needle height but it needed a bigger main jet. its a Keihin carb and all the spare keihin jets i had werent the right size but surprisingly the stash of mikuni jets i had from the VM22 on the trombone fit, so i went from a 98 main to a 105 main and it sorted and pulls like a schoolboy now. well thats after i got a new set of points and a new coil / condensor from malcolm at anaconda. the CB50 must have the condensor under the flywheel with the points but the XL needs it up my the coil, so in short it needed a new xl100 6v ac coil.
so that got it running good but the clutch was slipping bad, it had new clutch cover bolts and gasket so someone had been in there so i drained the oil as it needed a change and had and went investigating. whoever was in there didnt tighten the clutch springs up all the way so there was the problem, the clutch plates are also pretty dank looking so i swapped the plates from the other XL engine i have that has a bung kickstart shaft. the spare engine also had the tacho drive whereas this one didnt and its actually a super easy swap so i did that and swapped the side covers for the tacho drive hole too. all sorted!
so now it runs good and is pretty much finished, i just dont have the headlight on as i need to test that the XL engine isnt overcharging as they are an unregulated AC circuit for the headlight, once i can confirm that isnt going to blow expensive 6v headlight bulbs ill wang it back in and do some wheelies, which it actually does pretty easy with the CB50 gearing on it!
all ready for DGR this weekend
we use helicopters quite often in forestry, not just for spraying but for flying deadman anchor logs across gullies into farm land and my cable hauler contractors often use choppers for flying strawline across gullies because a chopper can do it in ten mins where as men carrying it would take 2-3 hours, if thats slowing down a entire logging operation that has a cost of around $10k per day the $1000.00 for the helicopter is well spent.
you should be able to get your stuff done cheap as chips with a chopper, as mentioned above go talk to your local outfit and find out when they have a job nearby so they can just quickly do it on their way back to base, talk to them about how they want it rigged up and get it all pre stropped and rigged up for them and it will literally take like ten mins and for 2-3 trips and save you soooooo many kilojoules
Also because sparkles and cams 125 destroys the two 110s on our rides, so def a big power difference, and the 140 destroys all. Top speed in the 125 and 140 are similar due to gearing, the 110s run out of puff a touch earlier. The gear spread in the 140 is shit compared to lifans, my lifan 150 is lush. If I was buying another engine it would be a 125, also shore50s can get 125 semi auto, which is what I’ll chuck on my next cub project.
clutches are better for wheelies tho.
and yea I had my 140 cub geared for 120kmh but it felt like it was going to kill me at that speed and it already has a tall first cos of the “racing” gear spread so gearing it up that much made 1st gear feel like you were taking off in third. I love it now, still not close to the limiter at 100 so it will set there fine but yea does hectic wheelies if first 3 gears easy which makes it mega fun to ride around town
Are you guys for real, fuck I have found the 125s I have ridden wayyyyy more powerful than the 110 lifans u have ridden. I’d never put a 110 in a bike again tbh, cost difference to 125 is minimal and I find the 125s perform closer to 140s than 110s. It’s more than just a cc difference. Cams 125 lifan is not far off my yx140, just more torque with the YX, both waggys and kyles 110 builds I have recently done I reckon are slow At in comparison. @Sparkle and @Dolan can chime in on this
are we going to need to cap the number or bikes? maybe something to think about so shit doesn't get bigger than we can handle? id say with 30+ we will probably self separate into two or more groups, so could have a support vehicle follow each group
13 minutes ago, datlow said:
having never done more than a few ks on a motorbike
whats your guys usual stash of tools for long rides/in general
im thinking
tube or two
tyre tools
few adjustable spanner or certain sizes for wheel removal etc?
spare plug and plug spanner
spare 4T oil
ive got a small 1/4 socket set
what else?
yea one tube should suffice unless you have different size wheels, can stash a wee puncture repair kit as well as your unlikely to have 2 punctures in one day. i wouldnt stress too much about tyre levers as there will be a bunch of us with levers, and you can get away with a screwdriver and spark plug tool for that.
correct spanners to adjust chain / axle and remove front or rear wheel, depending on your bike this is usually 10/12 and like a 17 or 20 for axle nut. it is very likely you will need to adjust your chain 2-3 times on the trip.
a small nut fucker never goes a miss
i wouldnt get too worried bringing a lot of oil, especially if your bike doesnt already drink a lot, stuff like a ct110 wont need any, if chinese engine maybe 200-300 mls but again probs not needed.
def a spare plug and plug spanner, find a small bike tool kit where the plug spanner is also a flat head and phillips screwdriver. i wouldnt worry too much about sockets, spanners will do the trick.
make sure you have the required tools to pull a carb off and whip the jets out in case it sucks in a bit of shit.
if you make sure you have the bare minimum for all that listed above you will find you actually need fuck all tools. there will be a big assortment of tools chucked in the support wagon not so much for during the day as that will slow us down but if someone has a major we can fix it that night and will have the shit to do so. ill bring a big assortment for the wagon and things like some brackets and bolts and shit incase mufflers rattle off and that sort of shit but again if we have those sort of issues its likely going to be on the first day and we have raizers workshop / welder that night so should be all gravy.
oh and cable ties, fuck loads of cable ties, they fix everything.
tl:dr dont go crazy as you dont want to way yourself down, but bring enough to change a plug, adjust chain and fix a flatty and you will be sweet.
- 5
16 minutes ago, 64vauxhall said:
Even after doing kms on your scooter things can still go wrong like Raizer on the waikato ride on his scooter.
But let's hope that won't happen and we have a great trip.
How many bikes able to two up?
youll be right mate, vespa isnt gunna be rung out like gyro was.
Just make sure you bring some of this so ya dont lose ya nuts
2 minutes ago, 64vauxhall said:
also swapa crates are not that structural for hanging bags off guys. buyer be aware.
for most people they will be fine, but for going full hunoos passing every other bike racing down the motu there is a high chance that the extreme velocity combined with fat cunt on the seat and limited suspension travel will cause said swappa crate to explode
Remembering that this year if shits gunna break its going to break on the first day, as thats when mechanical weakness will let go as its first big stretch / roughest road and also the most "difficult" terrain to ride. the benefit of doing the trip in the opposite direction this year is we will have gisborne / raizers workshop to fix non terminal issues so i think one should be enough. just dont do a @MopedNZ or @Shakotom and crash, dont do @64vauxhall and bring a pile of crap that had not run properly ever, dont do a @doozi and bring no spare tubes, or a @blizzo and bring a bike that has a tank full of rust that just blocks fuel filters.
tick all that shit off and you should be sweet
- 5
- 6
in Upper North Island Region
Hey guys I’m after a couple of ct110 parts for the spare bike im gunna bring up for this ride, a headlight bucket (can be bare) and a pair of headlight mounts, in after the later model mounts that have an extra part of holes for indicator stalks, I have a good pair same as below that I incorrectly purchased that I could part trade. Cheers
