Everything posted by ODB
a student stole ur phone???? now you are no longer a teacher you can go kick the living shit out of him right????
whens part 2???
If you look at metal heads v50 a couple of projects down looks about the same? Thibk mine looks worse cos it has different risers and bars
Yeah it's not perfect but sitting in 4/6 holes there. The ones that connect to engine are about an inch out mate. I'll have a play and if I need to drill more holes so be it. Needs to come off to sort carb anyways
Test fit of new legshield: doesnt seem to fit all that great - its for a yamaha 80cc mate/townmate i think but yeah Hides a whole lot of ugly in terms of airbox etc i reckon What you all think?
Finally got around to making up a cable for the front brake for this. It now brakes on both ends! Pictureless update soz
You are sweet. I dropped a large version of this into their letterbox au.
wish my old man had one of those - from when i was about 16 onwards and had my licence
i read somewhere that there are a lot of old rotangs in states and that they arent in demand at all - might be able to pick up some bits there?
Alrighty started pulling carb apart and became apparent last person to work on it had lost clip that was holding air intake on. Hence air intake was off and this was covered by black electrical tape. No doubt contributing to it running like a bag of dicks. So rooted around in my shed and found this - knew i ordered one ages ago: Far thicker than the old one, its flexible and seals both ends. Yeah
Its dying specifically when it has run for 10 mins plus and got hotter. Seems peppy lower down etc but def bogging hard at WOT. Will try adjusting clip to highest level - but my (rudimentary) understanding is that this only really effect up to about 3/4 throttle and WOT is the jet size?
Ok bike is back and seems to be running / starting well - when cold. After its been running for a while and gets hot it seems to bog down and stall. I need to let it cool down and then will run again. Thoughts? Initial thoughts could be running a little lean / soft seizing? So run some oil in fuel also? Carb jetting?? Perhaps gear oil needs changing although that seems sweet?
You fools talking 'bout rap oh what glee, Look out mother fuckers its the ODB. Hayholes mum you sound like such fun, Lets get this thing started with my fist up your bum. While all those other lads are making such a fuss, Your cooking eggs for me, like Im Jake The Muss. Im sure my sweet rhyming will get you all wild Your upcoming reaming will not be mild! Just had a look outside - probably gonna rain. On Hayholes mum, lets run a train! CHOO CHOO
I went into yahoo Japan auctions then got midnight racing to sort it which was fairly easy
That's what having another kid does to ya bro take note haha
overnight parts from japan and shit.... this thing is running now need to figure out a seat plan
Thats some good info - maybe a sticky? All of us wheeler dealers have issues transporting shit up and down the country with cunts asking moonbeams.
saw that bug - from auckland wasnt it? Was tempted - glad it went to someone here!
- 497 replies
think there is supposed to be a pivot of some sort on frame just below seat post entrance. The wire goes into the shifter where the arrow is facing away on the picture - if that makes sense and it pulls out / pushes in a chain that comes out of the rear hub. Will try and track down a photo of a complete one for you
Stripped down now - new wheel all good. Found one of these beasts browsing the tard over Xmas so thats arrived now: Rear hub / wheel getting dropped off at around again to get serviced and waiting for powder coaters to get frame , mud guard etc done. Anyone got any good sources for re-chroming or polishing? Want the mudguard holders smartened up a bit
Given back brake the same treatment today and found a new front wheel for it at Around Again Cycles. Waiting for a crank puller from fishpond so I can pull off that and send to be sand blasted and powder coated. After that it's re-assemble, new brake cables and seat covered and ride
Er nah sorry man. Don't happen to have a crank puller do ya? Anyone??
Few hours and a little steel wool later:
pretty much stripped down now - just enough to move it around easy left on lol Starting to look clean Front brake lever and caliper chillin like a villain in some white vinegar. This stuff mows surface rust - here is the seat pole which was pretty covered in the stuff:
Tear down has commenced. Well well well...... Sturmey Archer 3 speed AW hub Bit more research - appears to be one of these: http://bikewhistle.blogspot.co.nz/2014/01/1974-raleigh-supurbe-3-speed-with.html This may require a change in plans.....
