chris r
Everything posted by chris r
Part number says it came from a ibm 3277 I opened the board up and was pleasantly surprised. I was expecting it to be semi fucked but it's pretty good inside Dust cover thing was there but brittle and came apart when I touched it I had hoped it had the circuit board that would let me just order and plug in the USB converter. I've found this old thread where someone designed a replacement pcb. Will need to figure out who/where to order it form https://deskthority.net/viewtopic.php?t=16867
Before I ordered the other key caps I thiyght I'd have a look on trademe and see if there were any model M. There weren't but was a listing for a "antique keyboard" Chucked some bids on and in had a delivery when I woke up this afternoon
Headers arrived, looks like they have been on a low car and repaired. Should flow a bunch better than what I have on the car now, wont be easily able to tell power increase from the headers alone as I'll be doing cams as well before it goes back to the dyno First pics are from the auction Reapir looks good enough, I'll most likely need to modify that section to clear the transfer case anyway so not too worried My best guess is they are Fujitsubo super ex headers
And a quick vid of the Mrs typing on it.
Right so many hours later I've found the file/instructions and figured out how to remap the keys on the other converter so that two of them working and USB converted now This one is running the original control/encoder board with a teensy module attached to it - Can kinda see the teensy module above it there Ended up jumping between 4 different programes to sort out the mapping Had to figure out what key was actually being pressed then cross-reference it to the table of key tags/labels. The firmware I flashed into the teensy is called soarers converter and once everything is figured out you just need to create a text file with the remapping then enter that file into a compiler/flash tool Then everything will work on the num pad. I've mapped the tab button as a backspace and the old scroll lock button as the windows button for now
Neither did I hah. I found it when I was looking for the instructions/remapping stuff for the other module https://keebd.com/products/model-h-usb-controller-upgrade-ibm-model-m?syclid=cl43vgetuops738tu4c0&utm_campaign=emailmarketing_140968493208&utm_medium=email&utm_source=shopify_email
Got everything reassembled and alignment was surprisingly close. The car feels way nicer to drive now, the old rubber was way softer than I expected. I've scored some better jasma stamped headers which should flow significantly better than my rangid up 4-1. I'll have to re make some of the exhaust to suit but that's not the end of the world as I can get a bit more clearance around the diff and hopefully get rid of the rattle. I grabbed some k series fuel injectors when I was last at pick a part. They should have a much better spray pattern and atomisation compared to the older ones I have in there now. I'm curious to see if there will be any change in economy etc with them. Will find out after the re tune once I do exhaust and fit the cams
Remembered I had these in my hoard and had some inspiration to dig them out I'd forgotten how dirty they were I'd forgotten/lost the link to remap the teensy so cheated a bit and ordered that board which replaces the original control board Cleaned up the housings Tried a single keyboard worth of key caps in some dish soap. Left them to soak overnight and they came up pretty good with next to zero effort The cat helped me sort and group the key caps One cleaned and usb converted model m. Only thing is the num ad scroll lock lights are swapped around. I'll see if I can figure out how to reprogram that.
Ended up cheating and getting another usb module (model h board) will update my electronics thread
Time for a front end refresh on the orthia All the ball joint bolts are split and needed replacing. Got passenger side upright/knuckle out along with the the upper control arm. I grabbed a energy suspension urethane kit. I really like them /rate them. Have them all through the shuttle New ball joint and boot in the upper arm. Bit of heat and encouragement and the inner part of the bushing came out Pressed in the new inner bushings with my press tool Managed to get the lower ball joint out of the knuckle but haven't quite got it sorted yet.
chris r replied to sr2's topic in Project Discussion
That will work too. Depends if you want a 'fan is actually on' light or a 'fan switching circuit okay' light -
Revthe fan Switch side looks good/it'll work as drawn @sr2what do you want the light to do? If you want it to indicate when the fan is running then connect it to the 30 terminal of relay/in parallel with the fan itself If you wire it as drawn the relay/fan will always be on as it'll earth out through the bulb -
Been working night shifts so haven't had much daylight to do stuff. I haven't been awake when the weather has been good enough to paint to no clear coat Got a few mins today. Found some nuts and bolts in my box of bolts, drilled and tapped the strut towers And brace is fitted Paint isn't perfectly smooth and you can see a few sanding marks but it's good enough and will get scratched etc etc in time so I'm not too worried. Also found a cheap factory dual runner intake manifold to play with for another experiment.
So replacement spring has done the job and no issues so far. Popped into pick a part and grabbed the tank out of the shuttle there to replace my rusted one. Figure no rust + a soldered hole is better than Fucking around with a rusty tank. Also grabbed the d swries/shuttle output flange from the transfer case a quick rough measurement suggests the shuttle driveshaft might fit the orthia but I'll need to change the flange to suit Swapping to the shuttle diff shoul get more clearance with exhaust and hopefully stop the rattles
One of the springs in the left hand drum fucked out and it was locking up in reverse. Got the shits with them and started re looking into disc conversions again. Found a old forum post that someone drew up/3d printed a bracket. Send the file to my mate who printed it Attacked one of my spare trailing arms and got the wheel bearing/backing plate out and test fitted it For some reason I hoarded everything except the rear discs off the integra I parted out. Caliper almost fits But parking brake mechanism hanging off the back hits the trailing arm Looks like people in the states butcher the arm a bunch to get it to actually fit. So I went to pick a part and grabbed a spring to replace the stretched/damaged one
Other side done Thought I'd change the fuel filter but the one from rock auto leaked. I thought I was going mad/more mental when I was checking the oil and the dipstick was in different positions. The tube was loose and came out Have it a degrease and slapped some black rtv. Back in the hole and hopefully it stays there now
Would a external module work eg the bim023 (assuming your going wasted spark)
Found a piece of Ali in the bin someone had tried to dc tig with stainless filler rod and started on a bracket for the throttle cable Cut a angle so it'd clear the carb and let me access the retaining nut Have it a quick tickle on the sander to try and make a bit of a curve. It's still miles long as I need to have the ute handy to see where the throttle actually wants to sit
- 98 replies
Thanks! I was hoping something like that existed
