Escort Engineering
    Waikato
Escort Engineering's Achievements
Advanced Member
Advanced Member (3/5)
6
  1. if your still after some im sure its not to much of a hassle to machine some up PM me if you would like something.
  2. Dust seals aren't to much of an issue in my opinion because the piston don't retract into the caliper if you are going to run wilwood and ever have to change the pads just make sure you wash the piston with warm soapy water and a toothbrush, but im only going of knowledge of racing background
  3. Cheers guys I'll try and get some more pics up as soon as I can and have completed something.
  4. Thought it was time for an update so here it is ive been working on my sump for a few weeks now and it is almost complete so here are a few pics for you all to look at The sump started of as a ford escort 1.8l sump which i cut down This i it all cut down didnt take to long to do this with a milling machine Then i got to work folding and filing some 3mm alloy Here it is sitting on the motor it sits quite nicely i think I had to wing the sump aswell The sump still needs some work like the sump plug and a baffel plate and then the oil pickup and it will all be done hope you guys enjoy the pics
  5. May have been mentioned already but when welding alloy grind tungsten to a ball or on a slight beval , gas flow around 7-8 litres a minute and use a gas lens with a number 6 or 8 ceramic so you get fairly good gas coverage , when the pool in the alloy is astablished you will see it go very matelic silver like dull chrome you will see a swirl in the weld pool this is when good heat has been created and the two pieces your are joining should start to fuse, start traveling adding wire if needed but be cautious of the heat as you move along the weld you will have to start traveling faster or turn your amps down. Hope this info is of some help .
  6. Very nice keep up the great work.
  7. Yeah the angle plate would be sweet but no need for 45 degree angle with what im doing , as for the gussets don't think they are needed only time the load is really on the legs is when you take the lock pin out
  8. Hi everyone thought i would do a little article on make your own rotisserie, i made mine about 2 years ago and is probably the best thing you can make for working on your car, you can make one for around quarter of the price of a bought one and the main thing is that you can make it to suit the application that you want it for. The whole frame is made from 40x40x5 RHS mild steel. Im using my rotisserie for a MK1 ford escort i have mounted the front cradle on where the quarter bumper brackets mount with the two bolts that go through the chassis rail so all up the front cradle has 4xM10 8.8 high tensile bolts , the rear cradle is mounted on the leaf spring mount where i have used a M16 bolt to hold it in which is 8.8 high tensile. The pivot point in the middle of the frame is a m20x130 8.8 high tensile they are that long so that when you rotate the car on the bolt it isnt turning on the thread it is turning on the plain shank of the bolt. Here is a drawing of the end frame really easy to make. This is the front cradle which if using for a different car you will need to make them to suit, you can see the two bolts holding the frame on at the front Here is the back cradle it has two bolts through the chassis, you can also see the m20 bolts where the pivot is and the one at the bottom is the locking bolt. Hope this info helps someone out and make there project that much easier, best of luck.
  9. The turbo charged pinto sounds cool, yeah have thought about that box and most likely will get one further down the track.
  10. Hahaha yeah if i was still going the crossflow direction it would be more of a formula ford engine 120hp that would be enough
  11. This is the rubber mount i will be using in the gearbox cross member
  12. You could get a machine shop to make some AN- fittings out of brass i only say brass because it is cheaper and easier to machine then copper, then maybe you can get your local radiator shop to solder them to your header tanks, I hope this is of help .
  13. Here is a little more on the gearbox side of things i had to fabricate a new cross member for it that was 20mm lower then that standard one and about 15mm further back Doesn't have a rubber mount in there at the moment due to the supplier being out of stock
  14. Another thing ive been working on is the water rail for the zetec as the water outlet is at the back of the head Note: Water rail is not finished still working on the plate to bolt onto the head
