Everything posted by Muncie
Daves new school holden shambles. (And finally a Turbo)
The bits above go on the huffer itself theres a 5 bolt hub that goes on first then its a just 5 cap screws to change pulleys. These are from Mace engineering they sell various sizes and are really good quality.- 364 replies
- not as good as a barra
- ecoboost
(and 1 more)
Tagged with:
Haven't got car at home at moment so will be sunday before i get all this in one place. I bought the fancy pants Eaton pulley removal tool if anyone wants to try it out. Will take some measures before fitting.- 364 replies
- ecoboost
(and 1 more)
Tagged with:
Went for a 8 psi pulley setup its modular so i can swap them round as i see fit yes 8 psi is fuck all but stock is 4-5 psi so with the supporting stuff like the exhaust and tune already done it should round it off nicely and make it whine like my mrs when i dont put the rubbish out. will try find a cheap long block to rebuild with good pistons rods and a cam while i scratch my head about how to intercool it without blowing 3 grand on a kit from Aussie.- 364 replies
- ecoboost
(and 1 more)
Tagged with:
Well the new daily only set me back $1000 so the stonechip express is off the market and back to been a toy. Which now means.......- 364 replies
- ecoboost
(and 1 more)
Tagged with:
stripped all the covers off this weekend and gave the thing a good clean has definitely been looked after brand new carb and air filter inside. Previous owner thought it had low compression as it was hard to start and struggled to stay running, threw 12 volts at it turned key with a puff of engine start away it went.... and then died without picking up any fuel. Fuel pump is shot sucks up just enough to make it run not enough to do anything useful but it definitely sounds sweet with no muffler. It also has a proper oil system so a turbo would actually work on it being 610cc it would spool up a small one too. Right i need a frame.......
Wonder if its got a lister 7.0liter donk in it 90% of that glorious noise will be induction doorts.
Complete new frame i think may be in order. Rebuild is a priority these engines sound awesome so might look down path of something road legal.
So 2.5hp is cool an all...... Been looking for something a little bigger found it. Shits about to get real fun
Great use of an old leaf spring.
- 106 replies
- honda big red
- quad bike resto
- (and 2 more)
- 106 replies
- honda big red
- quad bike resto
- (and 2 more)
So been a while has it been put in corner of the shed and forgotten about? Hell no its become reliable transport it folds up and fits in my boot nicely ive ridden usually 2 up bloody everywhere. Im thinking of building more in fact. Oh and my son has discovered burnouts much to the neighborhoods disgust.
Finally found wheels so i could get the 17's off to be stashed away. Some lower profile tyres will look mint
could go real simple for the heater couple of pc fans drawing air from some 2 inch exhaust tubing tucked under exhaust manifold then flexi tube it ahead of radiator so you dont get fumes. would demist mint.
While your attacking the firewall should recess it 100mm so a Barra will fit..... Probably better to fit heater unit out of something 90's spec and Japanese the triumph units fill with leaves and rust out, or the internal gates seize and give you full time hot feet or wind in your face.
There is a user on here called sparrow hes dropped a lexus v8 in a stag same engine bay as a mk2 basically . Hes using my old independent ford 9" diff in it and my wheels from my mk1. See if his links still work.
My lexus to triumph sump was a 10mm thick flange with the pick up points for the trans at the back end, then welded the pan off an old small block chev i had floating around and modded pickup to suit. If you have a front sump supposedly possible to carefully cut the gearbox mounts off the ass end rotate the thing 180 degrees then weld back on for a rear sump. Not forgetting pickup mods too. Pretty sure steering rack will be in your way if front sump is tried i could be wrong though.
Lexus v8 is a bitch to fit in one of these i sunk one into my mk1 back in 2003 custom sump headers everything is tight and in the way. Ls1 with a camaro sump would be way easier Commodore headers would fit with a few pipes tickled.
Remarkably this thing is wof and rego'd as of today passed wof back in February. Currently been used by a sales rep at work to deliver grader blades face palmed the other day rolled up the door at work to find a massive digger bucket strapped to it. Had to call that trip off for him as im sure it would ended in death.
Swap you the motor off my scooter? //oldschool.co.nz/index.php?/topic/54857-daves-garage-dregs-combined-scooter-thing/
Might grab a spare set of carbs its not first time its done this my old man tells me today.
Tried blowing jets out with airgun and dropped drains on float bowls let it flow for a bit no real difference after putting it back together.
Just resurrected my long dormant bike its been parked up since 2002 my dads taken it on the odd ride here and there. But it has been neglected since 2010 so has needed a few new parts to get it to start again new battery coils and drained tank and float bowls today, Few shots of engine start in a can she fired up and ran on 3 and smoked like fuck eventually cleared itself, set off for a ride gave it some berrys and it cleared its throat and screamed to the readline thru the gears on all 4 cylinders. Sweet its cured i thought till i pulled up in the drive it died. Now it wont do anything but idle and it needs 3/4 throttle to achieve that any ideas? Its running on all 4 (pipes are hot) but yeah its not happy.
I had a TT Z32 11 years ago bought it with a blown auto box no one wanted to work on it so bought tools and a box out of a Nissan cima and threw it in. Tight to work on but not that bad. There's a guy on the nz 300zx forum's who writes chips for them that are real good mine with a single 3.5" exhaust sat at 12 psi with no boost control and was utterly lethal. Great work great car.
After several attempts to make the smaller chain work i just couldn't get it to stay on the sprockets, so after some head scratching how i could get a sprocket in 420 chain small enough to fit i ordered a 17 tooth front sprocket from a random dirt bike off trademe. After killing 3 or so drill bits it got 4 holes in it and bolted on it now works and doesnt throw chains. The carb however has decided to jam at 3/4 throttle and again at idle. Anyone know if a trademe universal 2 stroke carb might work?
