Everything posted by Muncie
Got a spare carby if ya need one? This SU better like E85! Hopefully this also explains why i chucked such a big fuel pump on it from the beginning.
Can anyone weld a flange onto a turbo for me?ive had a terrible idea and have all the parts to make it happen.
Pretty sure i have just over 100mm of 5/8 keyed shaft somewhere. Would that work?
I just sprung for this in end dead easy bolt on and forget. I did swap one sprocket for a 17 tooth motorcycle one to slow it down and help the clutch live. https://www.trademe.co.nz/1667334685
If anyone is keen on this its for sale pm me. Decided to only run 2 amps and i need to use my 4 channel for the application.
Kimjon's 110cc 4 speed pit bike motorised drift trike build
Muncie replied to Kimjon's topic in Other Projects
Just found these seeing as you have near production line going for your friends and could convince them to front up something. Save a lot of time and work even on second hand stuff. Will go look at one see if its up to the punishment. -
I'll be using my V-twin might have to begrudgingly find a go kart axle as that engine smashes anything thats not performing including wheel's bearings and riders. -
Where do you keep finding axles? Do you have a wrecker they come from, building one for my son now as im keen to hoon one as well. -
Haha hes probably fitted one by now its been almost 24 hours. -
How do you have time for a job! Envious of your spare time.... or the speed you achieve things one or the other. -
Nope been 3 years since ive hurt a wheel. The difference is i was looking for a chicks address i was visiting not at the curb.......what a dumbass.
At the moment its bad it tops out at 65 would only do 45 if it still had a governor. Its 16t to 17t thru a jackshaft to 13t with 42t on the rear 6.5 rim. Its made from leftovers of other projects its scary fast wheelstands when the clutch bites which also makes it shit to ride so is important to get it right.
Yup only limited by the chain hitting the ground with small wheels.
It might slip the clutch . Its not super overkill I'd try it might be a bit doughy or clutch wont fully engage at normal speeds. They grab fully at around 2200rpm recalculate back to that and see how fast that would put you. Depending where you intend to ride it might be sweet.
Motive parts supply co on Facebook are cheap. Starchy on trademe.
I used this https://www.gokartsupply.com/mobile/ratios.htm Then mixed and matched what i had and what could be bought to get a decent top end. Dont be tempted to gear it for max top end or itll be hard on the clutch down low i geared mine for 50ks at 3800rpm. Then you can gut the governor if you run out of legs.
I lunched a wheel today stupid stretched tyres! They offer no protection to the rim will keep an eye out for some wide tyres for it. Keen to see what 265's would look like all round instead of the 225's they were new and came with wheels at time not necessarily my preferred choice. Just a bad curb rash barely moving but once it contacted had to cringe and back up, will get it fixed.
Half a 12A as a supercharger ?
Naw crap i have 2 that size here It was pink though so no loss. -
Because general maintenance is boring snuck these bad boys in with a massive amp. 2 more amps to go in to run everything else need to save for some more speakers. Hidden real well and have bolted thru the floor so no one is nicking them in a hurry.
Swapped out spark plugs and liquid dinosaur filter this morning. Typical jap import the date on the side is 6 months newer then the car so thatll be around the last time it was changed. Full of black shit as well no doubt it'll be much happier idle improved instantly.
I like how you could fit a beer crate in front of the engine for a small dog or something else cool.
Definitely go the CVT regret using a clutch on mine it slips down low if i gear for speed have to rev it do death geared for fun and acceleration but have no top end.
When i used to do winter runs down to the south island if it rained my doors would freeze shut at the lake in tekapo. so I'd run an extension lead out and leave a fan heater on low all night while at the hotel definitely recommend. If you have bugger all in the way of door seals and gaps everywhere you'll want plenty of heat blowing in.
