For the rear I should just redrill for 5 studs. Has anybody tried the OEM starion wheels on the EX? Are the offsets okay?
Sorry but I just bought me an EX and I am in the process or rebuilding it. I have an ooportunity to buy a Starion for parts.
Thanks again
Thanks for the response.Does the rear subframe mount directly without modification on the EX? meaning mounting bolts? Do you know if I will need the drive shaft from the starion too?
Yes you are right the 5 lug wide body ones. Front struts annd hubs including rotors and calipers? My car EX has drum brakes will I be able to have those re-drilled to be able to use 5 lug wheels?Thanks for the info.
Hi Phil, nice build there and lot of information. I have a question for you I just picked up an 82' Lancer Ex. What parts from a Mitsubishi Starion would I need to be able to use the Starion wheels on the Lancer? Thanks for the help
