Everything posted by shrike
Hey all keen to validate some thoughts Had to drive a mates BF XR6T modded Falcon from impound back to his house the other day, has been tuned/reflashed (factory ecu) by a local guy and tbh it drives like a sack of shit All the low rpm/load doesn't feel right to me Anything under 3000rpm and low load it stumbled and struggled so from a 4L I was very surprised, drove it when he first got it and it drove a lot better, my old rb25det (r34) powered r32 drove better off boost, hell anything N/A ive driven drove better I suspect all the low load/idle off boost area is tuned wrong as it drinks fuel, smells rich and is really doughy, really need to up the revs to get it off in 1st and more then what a heavy duty clutch would need in my mind At low throttle load in 2nd under 2500/3000 rpm it really stumbled, had to drop it down to 1st a few times just to keep it going, cant run aircon as it just wants to die At 100km putting it into 5th and 6th it just had nothing there to pull away from the lower rpm 80km had to be at 4th or 3rd to keep it going Normally on a 6speed I would still be at 4th gear for 60km and I was having to sit on 3rd or 2nd to keep it going I suspect the tuner has re-scaled the tune to suit on boost and load and not left enough resolution at lower RPM/lower load to maintain drivablity or not adjusted it at all to suit the new inter-cooler/piping/exhaust Anyone have any ideas if I am on the right track? car makes 280kw
So after much swearing, and me putting engine mounts on upside down. We got the engine and gearbox in (no clutch) and the car rolling with all the parts either reinstall or inside it Need to reinstall the turbo wastegate Whole thing was a pain in the ass, also slightly fustrated with my mate who pulled the rear cradle and fuel tank out but didnt actually fix anything But at least its rolling so can be moved on the 17/18th July
Nit a huge update and no pics this time, will go back to work on it Sat as I need to get it rolling again as I may be going to QLD for work and need to mkve it to the new house. Fixed almost all the wiring in the engine bay, have brought an evo 3 engine loom in Auckland which is going to my parents then being shipped to me Also picked up a n/a 4g93 auto ecu, auto computer and loom for cheap as it will help me work out the wiper motor loom and whats missing off that etc plus a few other plugs. Need to plug everything behind the dash back in and check the factory fuel pump will prime off the key but think most of its sorted. May try get an RVR ecu, my speeduinos are in storage and impossible to find along with my wide band, found the knocklink though so thats a plus One of the aftermarket hardlines was kinked with a pin hole so need to replace that, I may just hook up the factory fuel lines again for now though
Heard a few good things, and Andre has mentioned them on HP academy before. Its just a guage will hook it up and report back once the cars going
Just realized what I pulled out of the fake evo and I thought was a link knock block light is actually a knocklink, will see what the wiring is like and wire it back in, will help with my speeduino tune so score will be good to have some indication of knock and will make the tune less knock prone due to not having knock control. Just need to raid a factory 4g63 knock sensor plug off one of my looms and work out what the wiring is https://dealers.linkecu.com/G4KNL
Looks pretty tidy is it all legal?
Pulled the seats and carpet out to inspect the wiring further, managed to remove some of the sound deadening dynamat tar in the boot as well Ripped out the haltech loom (had to cut a couple of plugs off as they wouldnt unpin) and its other bits, pulled out the extra relays in the engine bay and the 2nd headlight loom. Unwrapped the alternator wiring which ill need to rewrap Rvr loom is in so need to work out how that will be run with the GSR dash loom, might grab some plugs or a loom from a GLXI lancer to use Found the positive wires from the fuse box which have been butchered so will get a new battery loom, might grab another fuse box as well Dash loom seems salvagable so will leave the one in the car for now, the spare one has been good for reference. Still need to plug heaps back in, and then get power on to test. Waterblasted/degreased the engine bay as much as I could Car is now on stands and has the fuel tank and rear cradle coming out, rear calipers are seized so will get seal kits for them along with Braided lines The aftermarket alloy pipe fuel line isnt the best job so may need to replace it, ill try to tidy it up/unkink it first though Abs sensors need a clean up as well Will be doing some underbody cleanup and then reseal it Heading to the wreckers tomorrow morning for a few parts (list keeps getting longer) and then will take more pics at the car Will reuse some of the relays from the dodgy wiring Ordered a release bearing, and have an Amayama order to go pending on tomorrows part mission
Had my Arp flywheel bolts arrived and seems I ordered the wrong ones so have ordered the correct set. Fuel hose and 25amp wiring spools have arrived Also the other spares I got from interstate, should now have everything I need to get the car back together pending the flywheel bolts and a clutch release bearing Grabbed some other things out of storage but still can't find my two Speeduinos, wideband and all my wiring gear and relays :s also ordered the module I need for the speeduino to run the factory Mitsubishi idle control. Have done a wiring diagram in Excel for my plugin patch loom and made a really safe basemap on tunerstudio. Will need to get a paid version of Tunerstudio later on. Plan for tomorrow is to get the fuel tank out and empty of old e85, replace the fuel lines, rewire the externals and make sure the intank pump is ok Check the dash loom and possibly put the spare one in, unpin the haltech ps1000 loom and pull it through the firewall. Might get the factory loom back on the engine and maybe buy a battery so I can test the cars wiring works. Will have to wait to wire in the speeduino till I move house and unpack. But will get the car back together and do that last Still heaps of Dynamat Tar to remove as well :s
So picked up a 2nd hand flywheel and exedy 6puk clutch yesterday for a good price, ordered arp flywheel bolts and a new release bearing. Will be strengthening firewall for the clutch master to reduce flex as well. Clutch is alittle worn and has a few minor chunks missing but was cheap and will get it moving, can buy a new plate if I need to. Pulled the dash out (had to cut multiple cable ties that had wiring attached) Managed to pull out the alarm, and the dodgy fuel pump wiring. May have to redo the factory fuel pump wire and repair the door/boot sensor the alarm was tied into Also got most of the engine loom out, will have to unpin the connectors to get it through the firewall bulkhead however. Ive got a spare dash loom to go in if need be, might also get another fuse box and the other engine bay wiring to bring it back to factory Confirmed they are Koya racing rims so emailed them about info and center caps
Just go 3" :p
https://www.everythingfuelinjection.com might be another option, Nick who makes these is great to deal with
Slowly buying parts to get this thing upto standard Cusco engine mounts from RHD Japan as it came with no gearbox mounts/brackegs and wrong mount on the engine. At least ive got all the engine mount brakets bolts etc now, have transfer case supports and the transfer case bolts ln the way from a guy in qld, also got the flywheel inspection plate cover. Still missing the cv bracket bolts (will grab them from pickapart next time) and the plate between the gesrbox and engine, ill either make one, mod the auto one or buy one from Amayama. Have 25ft of ethonal safe 11/16" hose on the way and 2 30m rolls of 25amp rated wire (red and black) Picking up a mint dash loom saturday just encase the current one is too butchered. Grabbed my two speeduinos and wiring tools etc from storage, couldnt find my wideband so may buy a Spartan 2 so I can get it running. Other option is just tune it super safe with the narrow band :s but not super keen Still need to get a clutch and flywheel, rying to get one 2nd hand but can get a genuine flywheel locally as nos for 215aud I keep finding bits missing and questionable work, ideally need it drivable by Aug as thats when my mates moving into my new house
Car arrived yesterday, still trying to work out if I got a good deal or not but im still at the point of making more then what I paid if I part it out. Its missing a lot of stuff, and there is some real amateur/unsafe work done Test fitted the intercooler and front bumper (needs mesh and the rad/intercooler painted black) its just cable tied in the pic and has now been removed Came with a cut bumper crash support and a few mods to fit in I supect intercooler/intake piping Paint is ok from far but far from great, will need a full respray at some point and ill do the engine bay and boot once they are cleaned up Went and grabbed a heap of parts of a lancer wagon at pickapart, also have gearbox mounts/brackets, cv bolts/washers and a better set of headlights with indicators and springs. Will probably buy some orange indicators off ebay later on. Will probably need more brackets and nuts/bolts etc to get it back together. Aircon needs a radiator which ill sort out later to be complete, the front knuckles have some play so hoping its due to no cvs and that the bearings are ok, If it needs new bearings ill be getting bits to 5stud convert it including wheels Car arrived with the camber maxed out one way so the wheels stuck outside of theguards a fair whack, my mates adjusted it back slightly and it now fits. Rims are Koya I think and are 17x8 +30 Wiring is shocking, will pull the dash out and see how bad it is but so far its had a haltech adapter loom plugged in (im not sure if it thats the case though) an aftermarket alarm, lots of crimp connectors every where etc, extra switches, additional relays and fuses for I dont know what so will try put it all back to stock or get/ make a replacement loom for it. ive got the loom that came with the engine as well Fuel pump setup is a concern they didnt use e85 safe hoses and they are now perished, on a plus they did use hard line as well so just need to drop the tank for a better look. Will be redoing the fuel pump wiring, I beleive this currently goes to the fuel pumps Also will be rust treating the spare tire well along with removing the dynamatt reside that wasnt cleaned up properly, any tips? Thinking ill use the old fuel in the tank to help disolve it. Boot lid needs realigned, so will tidy up one of the corners on my spare one and install that Will pull exhaust off so I can pull the tank, so will inspect that, I think it may be too loud so will look into adding a muffler, also not sure it has a cat so need to get one of them too. Currently the exhaust has a rear mount that doesnt go to anything.
Car is getting pick up today, seller sent me some pics (sprry for bad quality) transporter will send me pics and more info when he gets it so updates to come RVR loom has had auto parts cut out :s but means ive got spare plugs etc for my adapter harness if needed Seller is also going to post me a flywheel once he gets it off a mate, should arrive sunday so ill make a list of whats missing and go from there. Moving into the house I brought on the 16th of July so aiming to have it either more together or drivable by then
Give them an email, they are generally pretty helpful, ive also brought a teensy powered setup off one of the guys on the speeduino forum (they also sell kits etc off the forum) What features are you after, only things off the top of my head it doesn't do is super fancy variable valve timing (vvt and standard vtec etc is fine (on/off)) and no knock control without additional modules. But the code keeps advancing so may have changed. They are great bang for buck on cylinders and can even do full sequential fuel and ignition (4cylinder) also base maps for mx5 are plentyful so you don't need to start from scratch
Speeduino do mx5 plug and play kits alot cheaper then the megasquirts, could also just get the basic kit and make your own harness adapter etc They use Tunerstudio as well https://speeduino.com/shop/plug-and-play-units/22-miata-nx5-na6-plug-n-play-speeduino.html https://speeduino.com/wiki/index.php/MX5_PNP https://speeduino.com/shop/plug-and-play-units/28-miata-nx5-na6-plug-n-play-speeduino.html https://speedyefi.com/product/miata-90-93-pnp-speeduino-ecu/ https://diy-efi.co.uk/product/speeduino_mk1_mx5_pnp https://speeduino.com/shop/
@chris r know anyone with a 3dprinter? Get a space plate made with injector bosses in it along with points to mount a rail onto
Car arrives a week from Sunday Picked up these for it off FB marketplace for $100 they are mint, may get a lick of paint/plastic dip along with a new set of clips before they go on the car Those that know early 90s lancers will understand how hard these are to get May pick up a brand new in box 2nd hand GFB blow off valve for it next week as well, my mate picked up an engine stand and crane for me today Will pick up all fluids for a service next weekend, will paint engine, replace seals, timing belt etc before it goes in and then reuse them on the new 4G69 shortblock I build up when thats ready to go.
Few teaster pics, the seller has sent me Also brought a cc lancer boot lid (no holes) for 120 including shipping, seller polished it up and its looking mint. Had a $5 1.8 lancer ecu arrive that ill take the header plug off to make an adapter harness with Going to order some reproduced stickers from the uk for it as well, need to work out if it has evo front guards or not. Once it arrives ill make a parts list and start slowly ordering bits, trying to get some FTO front drive flanges for a 5stud conversion down the track but not finding much.
Evening All, not quite old enough to be classed as oldschool yet but being a 1994 model and 26yrs old its getting close (I hope) For those that know me I still have an Ae111 in Levin in Nz thats slowly being built, I havent put a buildlog on here as I have one spread across a few other forums. Come Christmas this year Ill have everything needed for it to be finished and will be getting a timeline off my fab guy for completion. Due to now having space and some funds I can spare, along with more time. I have been keeping an eye out for something to tinker on and setup as a weekend/mild track day car So I have purchased a sight unseen 1994 Australian delivered Mitsubishi cc Lancer GSR from Queensland and its being delivered on the 24th Its white so matches the other cars in my collection, seems pretty clean from the pictures Has a larger fuel system, coilovers, catback, larger brakes and a few other goodies. Its also fully mod plated for a 4g63 and the other mods, so I can register it. However its currently a rolling body with an RVR engine coming with it. No factory ecu or the aftermarket ecu it used to have, so im going to be doing so wiring to get the rvr ecu going and then will go to a later model evo ecu or a speeduino The RVR engine is also the 2G style one which has a smaller turbo and is prone to crank walk etc Will post pictures when it arrives Current plans are get it all together, running and legal. Get an N/A 4g63 or a Hyundai equivalent to build up with a 4g69 crank, forged rods/pistons etc to swap in later Hopefully I don't have to many surpises when it arrives.
So I sold this to a learner driver for 1300 as I got a 2013 Liberty Wagon to replace it with, and the Girlfriend got a workcar not long after. I wanted to keep it for track work but the 1gfe was tired and I had limited space. Shoukd have updated this 2years ago
Convert to efi would be high on my agenda after getting it legal, use a speeduino etc
People run Barra Ecus on the sohc AU engines as well
Ive got a teensy 3.5 version cost me 229 delivered and assembled just had to source a teensy. In storage atm as the car it was going in I sold https://speeduino.com/forum/viewtopic.php?p=36280#p36280 Nicks a pretty good guy and very helpful
