Everything posted by SOHC
Thats the way I ended up fitting it, it slides down the stub and that steel plate is just a shield, I tried fitting it the other way with the hub packed with grease and some oozed out.
They go on the stub and then press on to a tin cover witch is presed into the end of the hub
Witch way wound would one fit this hub seal? It dosnt have a spring and is totaly different to the old ones
The down tube on the front of the frame had a budge in it about 20mm,managed to pull it back, also it was off to one side by about 20mm, got that good to, I will have to do some more measurements and see if its not bent anywhere elce.
I forged some stub axles for a Mercedes and a RHD converson steering link for a Chevrolet, heat cycles are not any worries. Heating and beading parts might be founded apon.
You can make tapperd holes by cutting the end off an old tie rod end and then drill a hole in the arm to the bolt size and heat it orange hot and drive it in.
Fitted new custom made tool steel steering head bearings and the front end, I am not going to use this frame as its a but shit, I should have looked it more, I have another one that looks way better.
Rebult forks with new bushes and staunchens, way more work making things fit and work because of shitty reproduction parts.
A new pair is $250, I have ordered them and a fork rebuild kit, got some McIntosh steering head bearings to, front end is going to be very nice
I got a roadholder front end, its an early one, stripped it down and with out fail its fucked, I had some commando staunchens but they are too short, so have ordered some longer ones, some new bushes and seals should see it working again.
Had to cut the rear lower engine mounting lug and move it up, and cut the front lugs down. All the frame mods to fit the big4 engine are done, just need to make the engine and gearbox plates.
I could score you a 2L motor if you need,
They probably got the letter to
All back together now, its a huge amount of work to remove all the studs and clean everything and seal and install all 48 studs. I will heat cycle it once and re torque the next day, then drive it up and down the road then re torque it the next day and keep doing that till they settle down, probably have to do it 4 times.
- 69 replies
I have had a problem with coolant seeping out of the head studs, I took each stud out as I re torqued the heads and put on some locktite thread sealer, this did not work with the aftermarket studs, I am going to put silicon on the threads and also use copper spray on the gaskets this time, I would have used if i built the engine anyway. This engine was never intended to use antifreeze, my 1938 motor didn't mind it but I think that thing had alot of internal rust sealing it.
The mk4 zodiac box it fairly strong but has a fine spline, a Mitsubishi truck clutch plate works,
Got this back together a wile ago, gearbox was stripped and inspected and was fine, got a new drive shaft made, now all gearbox oil leaks are fixed apart from where it weeps from the sector in the top cover but I am not worried about that, misfire was a loose vacuum line to the distrubtor, thats fixed, onto the 3rd oil pressure gauge now as they keep failing, going to fit an industrial one soon as automotive ones are total crap. I have been so sick I have not been able to do much, its like tighten 4 bolts then go to bed.
- 69 replies
- 16
