Honda ATC 250es thread
Jusepy82
Hello friends , so I decided to get my 84 honda atc 200 a big sister , although she is a bit sick at the moment.
I brought the 200 and got it going well but decided I needed another trike in my life.
Sooo I brought the 250es from a guy up by Horopito car museum.  Got it for a steal but boy it's a big job.
frame rusted by foot pegs, motor not running , massive oil leak from left hand side cover . I have fixed the side cover gasket and also had the motor running now.
I put the 250 up on stands tonight so I could make this build thread.  So far I've brought a second hand CDI for it , brought another rear rack and fixed the wiring and repaired the wiring behind the kill switch. The previous owner couldn't get it running.
I plan to get it purring , then strip it and repair the frame.
cheers. Sorry bout the novel.
top bike is the 200es that hoons.
Tonight I had a look into the carb over fueling as I had to drill out the slow jet as it was blocked solid. I ended up drilling it out but I think its fucked now as its pouring fuel out the back of the carb. So I disassembled the card , ready for when I buy a carb kit for her.
I thought I'd look into the wheel bearing play on the left hand rear wheel.
Took the castle nut off, which was loose, had a quick look at the splines of the hub. They looked ok, so I tried to crank up the castle nut to no avail. The split pin wouldnt fit through the hole as it's not wound on enough.
I removed the hub again and had a look at the wheel bearings and it seemed they wernt pressed into the axle tube enough. So I punched out the bearings and cleaned it all up , what a mess !
Anyways reassembly another night as I'm dangerously close to too many beersies for this kind of mechanical work.
Cheers
This frame seems solid enough, I'd better check it's not better than mine hah! A little bit scabby paint but not chunks falling off or anything.
Someone's done a bit of a hate crime on the RH peg mount and put bigger bolts through with nuts, unclear why. I'd like to hold onto the pegs probably
Screenshot_2023-03-25-13-56-25-501_com.google.android_apps.photos.thumb.jpg.f6331510f90382e29a12c07e5c1a4ef8.jpgScreenshot_2023-03-25-13-56-29-766_com.google.android_apps.photos.thumb.jpg.cb67e9a8bad61313c0b78d413b39b4ab.jpgScreenshot_2023-03-25-13-56-32-442_com.google.android_apps.photos.thumb.jpg.e7757d8357a36d8322a4ddafe510c9b4.jpgScreenshot_2023-03-25-13-56-36-819_com.google.android_apps.photos.thumb.jpg.03d5ff12f40d62f90321e50e07c5b1fc.jpg
