MRT1TRD Posted July 29, 2022 Author Posted July 29, 2022 Anyway treat and paint what I can inside door 5 Quote
MRT1TRD Posted July 30, 2022 Author Posted July 30, 2022 On 20/07/2022 at 20:01, MRT1TRD said: With a little adjustment the bmw B Piller worked a treat 6 Quote
MRT1TRD Posted July 31, 2022 Author Posted July 31, 2022 Most of the wood was too rotten so chopped most of it up. 6 Quote
MRT1TRD Posted August 11, 2022 Author Posted August 11, 2022 I pushed it off the trailer but half stayed on Sorry no pick, no matter how much I crop it it's too large to upload but there was a lot of rust left 4 Quote
MRT1TRD Posted August 13, 2022 Author Posted August 13, 2022 When I first seen one of these I was Abit confused with the two pistons side by side, but it makes alot of sense having the brake and clutch all in one. 3 1 Quote
MRT1TRD Posted August 21, 2022 Author Posted August 21, 2022 The seals looked ok and I made some new gaskets then put it back together. Then did a bench bleed to see if it is working. It works ok but eventually sticks and does not return. The cylinders looked good but looks like it was resleved with poured copper then honed to suit. Guess I have to send it away for stainless sleeves. I will pull apart the other one first and see what that looks like inside first. (Outside was heavy pitted and had some dirt nests inside) 8 Quote
MRT1TRD Posted August 24, 2022 Author Posted August 24, 2022 Content to keep the sponsor happy 6 Quote
MRT1TRD Posted September 3, 2022 Author Posted September 3, 2022 Think I am going ott for this pos, the idea was a rough and ready restoration to try and motivate me into finishing the bluebird. I was not happy with the lead covering the little holes along the bottom so I cut that too. Then after cleaning it up I put the rust prevention on. 3 Quote
MRT1TRD Posted September 6, 2022 Author Posted September 6, 2022 Enough peaches for this door time to work on another 4 Quote
MRT1TRD Posted September 7, 2022 Author Posted September 7, 2022 I removed the last bolts holding the front of the s2 on 2 Quote
MRT1TRD Posted September 9, 2022 Author Posted September 9, 2022 This is what the bump stop mount is ment to look like Quote
