  • Replies 73
So I cut into the outer skin to cut the large bit so I welded them but found the lead skim coat that was under the bog skim coat
I will get the other body home before I decide if they are too far gone.
Anyway back to the door, I cut up a e46 bmw for this patch to save on bending time
So on the other corner the outer skin looks good but with a skim coat of pb since the other corner seemed thin under the lead I ground it back to find lots of rust holes.
Before I started I thought it would be easier to cut the lower 75mm of the skin off rather than infolding the edge to repair the inner. Maybe next time.
There is down side to owning multiple homes, things that you want can be at the other house when you want them. So I own a panel folder but have to improvise like I used to.
