Geoff Rohde Posted August 2, 2021 Report Share Posted August 2, 2021 Hi to you all. I am in the process of wiring up a 1998-99 1UZ-FE VVTI from a Japanese imported LS400 Celsior. Im using an immobilised ecu courtesy of KG in NZ. Getting accurate responses to some questions has been difficult so i thought I would try my luck here. I hope someone has this knowledge. Yes/ No. The only diagnostic wire in the body loom that connects to the ecu appears to be TC in plug D, pin5( a 28 pin plug in my application) I assume all other must have originally run to dash plugs and the like! I have a 10 pin transmission selector plug, I have detail on inputs to pins 1 through to 9, nothing for pin 10. Is pin 10 used or not? ( Im using an LS400 selector from US) Oil level sensor wire / plug location- not present in the body loom? Do I need to run this separately? I think this is for transmission oil level. I will run a separate engine oil pressure gauge( to what psi 120 ?) Output body plug wire, blu/red pin 8 to PARK. Do I split this wire and feed one to trans selector pin9 Park and the other to ecu, plug D, pin 15 P Similarly, Body plug wire, light green/red, pin 9 Neutral, split this and feed to pin 4 shifter and the other to ecu, plug D, pin 20 It appears that both the transmission gear selector and the ecu both need identical inputs for Neutral and Park. Correct?? RSPD, shift lock- just make sure this has a 12volt supply? And lastly, ECT power mode input, just run wire to earth to provide full power always. Correct?? I hope to fuse a few ecu inputs, Batt, +B1,, +B etc. Any idea of recommended fuse size, was thinking 7.5 amps. Any help on any or all of these questions will be much appreciated. Regards, Geoff geoff@shingokankaratemountgambier.com.au Quote Link to comment Share on other sites More sharing options...
Liath Posted August 3, 2021 Report Share Posted August 3, 2021 Hi Geoff I found www.lextreme.com to be the most comprehensive resource for all things 1UZ, especially wiring pin outs - the search function on that site will e your best friend. Quote Link to comment Share on other sites More sharing options...
Geoff Rohde Posted August 7, 2021 Author Report Share Posted August 7, 2021 Thanks for that. Im rather fortunate that Phil Bradshaw has assisted me with some of my concerns. The "other " guy just wants me to send more money for ongoing support and at $175 an hour for a handful of email responses, I think I will pass and pursue other avenues. I've already directed over 2g in his direction for components that Ive since been told should not have been more than $500. Quote Link to comment Share on other sites More sharing options...
johnny.race Posted August 8, 2021 Report Share Posted August 8, 2021 On 07/08/2021 at 12:02, Geoff Rohde said: Thanks for that. Im rather fortunate that Phil Bradshaw has assisted me with some of my concerns. The "other " guy just wants me to send more money for ongoing support and at $175 an hour for a handful of email responses, I think I will pass and pursue other avenues. I've already directed over 2g in his direction for components that Ive since been told should not have been more than $500. Who's the other guy? Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted October 2, 2021 Report Share Posted October 2, 2021 was the other guy old mate "NaN" What I actually came here for was to say, you should talk to kelvin from car tune company. he has allot of videos on you tube, has a wealth of 1u information. Seams happy to help anyone. Quote Link to comment Share on other sites More sharing options...
