Vk304's 1985 vk commodore
Vk304
  • 7 months later...
  • Replies 85
My muffler cracked all around and pretty much fell off after wiggling it.
so have started a twin pipe out the back, replacing the rudimentary 2.5 inch twin to 3 inch that i had, will now be twin 2.5 inch all the way, its tight but i think itll work
  • 3 months later...
Well after a bit of troubles at home ive picked myself up and started stripping the engine bay for a paint, and got a cam, just buying the cam chain set soon and ill teach myself to dial it in. Cant bring myself to pull the whole motor so may be a slightly awkward paint job but we will see
Made a little valve spring compressor thing to compress them out of some 5mm steel, have managed to do one bank today, definitely more pressure on the valves now, used air to hold valves up while swapping them out, tedious but not a hard job. . .
  • Like 9
Passenger springs, hardened locks installed without a hitch, all pushrods look straight and true, no funny signs of wear on the valvetrain and none of the valves leaked air through the intake when i was installing springs which is good
Intake off to remove hydraulic lifters which ill give a clean when i research on what the best method is, and gaskets will now be added on things to buy .....
Probably do a little porting on the intake and throttle body areas now its out too...
  • Like 8
Just wrote a whole story and hit 'c' on accident grr, anyways i started today on the intake and slight head porting/matching/opening up passages, only very slightly smoothed out the passage in the head.20231024_152910.thumb.jpg.a33bb0bb171193c24c37efd361ca345d.jpg20231024_152844.thumb.jpg.01a43df24487f034073a3f2181c791b1.jpg20231025_131201.thumb.jpg.711c694931652dd3bc728d8cd78e9672.jpg20231024_152857.thumb.jpg.8006b0d7071b6a0b0ba1cde504fc0667.jpgTook a lot out of the bend areas so it has a straighter shot at the valves, also opened up the intake plenum ports a lot as they narrow up just before the head and are significantly smaller than head ports...20231025_083722.thumb.jpg.ef7d25e62009aa1d76386eb7a3a084fe.jpgCleaned up hydraulic roller lifters,  soaked in petrol for several hours, they seem in good condition so dont feel the need to replace.
Comparison of holden 5l hydraulic lifters vs hydraulic roller lifters-20231025_112837.thumb.jpg.95dab2de80b16e2a011333501e76c542.jpgCleaned out by removing retaining clip, blowing compressed air into lifter untill bore pops out, can take a bit of back and forth...20231025_075521.thumb.jpg.e6af5488cf0be445af0957c738671c2d.jpgBit of gunk in them, cleaned out and put fresh oil in them before re-assmbly to have them pump up as soon as engine starts again, also blew out roller needle bearings and put fresh oil on them..20231025_121636.thumb.jpg.7b46da373e467004edea6bc41e9152b9.jpgKept them in order to have them go back in their respective bores, this is is just maintenance and checking for wear really, but she passed qc and now onto the cam chain and cam ...
Mace is providing me a good chunk of refund as they cant make the memcal happen, im fkn stoked with that! Good on them to do that even though they diddnt have to, because my setup is not a factory setup, but i did ask if they needed more information about the setup, before they sent it all.
Today was stage 3 of filling, by far the most sanding...., now it gets a few days to dry as i do a work rotation, then probably one more round of filler for any remaining pinholes, then primer...
I want to get it as smooth as possible to not have to do heaps of primer-filler coats.
The factory holden production panel markings/ripples etc are still there, to make it look original-smooth ish.
  • Like 9
