23crate Posted October 10, 2020 Posted October 10, 2020 hi all, does anyone have any info on part numbers for bearings etc for these kits please.. i know i can source kits from overseas, prefer local Toyota NZ can supply one bearing ok and way cheap too.. any help gratefully received .. Thanks Al Quote
sheepers Posted October 11, 2020 Posted October 11, 2020 The man you want to talk to is @sleeektoy 2 Quote
Taistorm Posted October 11, 2020 Posted October 11, 2020 Take the bearings to ABD in wairau, they're likely able to have some stocked or be able to get them in. Should also be able to get seals through them or Advance seals in Rosedale. Quote
sleeektoy Posted October 11, 2020 Posted October 11, 2020 Pretty much what @Taistorm said. If its just bearings you need, crack it open and get all the bearing numbers then rock up to a local specialist bearing wholesaler/distributor. North Shore Toyota regularly bring in the gasket kits for gearboxes too. Last time i rebuilt one I actually got the kit from overseas as it worked out more economical when it comes with the synchros and gaskets etc. Quote
Taistorm Posted October 11, 2020 Posted October 11, 2020 I've also used gearbox international in New Lynn for synchros on a few different vehicles before so might be worth giving them a call. Quote
