DeWetSwanepoel Posted July 12, 2020 Posted July 12, 2020 Good day from South Africa! I am new to the forum and hope to use you for some information. Me and my brother are busy with a 1UZFE conversion into his 93 Hilux. We bought the engine and 4 speed auto box pre-wired and we're unable to find a 4 speed shifter. My question is whether it will work on the 4 speed gearbox? And if someone can assist me with the wiring diagram of the shifter. Unfortunately the plug was cut off so it's difficult to trace the wires to the existing pins. Thanks in advance! Regards Quote
cletus Posted July 12, 2020 Posted July 12, 2020 Welcome! I did a similar swap 14 years ago but I cant remember any specifics on wiring, other than it worked with the shifter position switch on the side of the trans not hooked up, but it did weird things when shifting manually. I wired the switch in and it was good after that. I used a generic aftermarket lever type shifter, a b&m unimatic I found www.lextreme.com handy when I did mine, i just had a look and it appears it still works 1 Quote
nzstato Posted July 13, 2020 Posted July 13, 2020 Go to the godfather of the 1UZ.... https://www.youtube.com/user/CartuneNZ He has a few vids up on the transwiring, how you can go manualising etc... Quote
