  • Replies 90
Building the 1961 Datsun 310 Bluebird - RHS ‘B’ - Post Repairs/Build. Part One.
As it was in the beginning. Rusted, rotted from the inside out and battered with abuse.The abuse happened many years ago whilst trying the bend the pillar next to the front glass. I had placed lumber in the door frame opening diagonally then applied a hydraulic jack. before I knew it, the B-post base was collapsing and getting crushed. So i've a combination of rust and aft direction post damage on three sides to repair.
So, a flood of pics to follow, starting with the damage detail, rust repair of the lower flanges, opening up the inboard face panel by removal of the lower 10 inches, beating the damages back into shape, welding it all back up and grinding and sanding it all smooth.
The underside and after detachment from the original structure.725411071_61BluebirdRight-B-Pillar-4.jpg.cb244960482bb647dfe5374996c550c5.jpg
As it mates on the new sill.
The buckled inside panel with a heavy crease and rusted bottom flange.
Made a patch assembled out of three pieces and fitted it for the aft lower face.
Similar for the front except made it out of one piece which took way too long to make.
Had to make a relief cut and weld in up anyway.
Decided it's better to stick with multiple pieces for a complex and tilted curved surface intersecting a vertical plane.
More welds added to plug the holes made from disassembly.
Backed it up with copper during weld to keep from making the holes bigger in the thin metal.
Underside now begins to look a bit cleaner.
Cut the inside panel to gain access and make repairs to my prior mistakes of old.
Innards.
After panel beating the crease smooth, fitted up a patch to repair the rust.
Then started tack welding it together.
Other side with my ugly series of tacks.
Smoothed out the welds.
Removed the inner bits. Just needed a bit of cleaning and then weld back in.1183899155_61BluebirdRHS-B-Post-23.jpeg.bf2d2f3053306ffdfcfacf720b32ab10.jpeg
Surfaces inside the post were better than expected with lots of clean metal in places.
An easy cleanup in preparation for reassembly.
The abuse damages are fixed (beat flat) and ready for closure.
A thin coat of copper primer for the insides.
(To be continued next post.)
Discussion:
https://oldschool.co.nz/index.php?/topic/60267-marts-pl310-61-datsun-bluebird-sedan/
Build:
https://oldschool.co.nz/index.php?/topic/60264-marts-pl310-61-datsun-bluebird-sedan/
  • Like 9
  • 10 months later...
Building the 1961 Datsun 310 Bluebird - RHS Floor Pan - Installation.
Extra pics to previous post.
I made some in sequence hot video screen captures doing a plug weld on the floor install.
A lot of fun it was moving liquid steel around and around!
  • Like 9
Building the 1961 Datsun 310 Bluebird - Front Seat Springs.
Soliciting some thoughts on seat springs. I'm working on the front seat and am now at the point of assembling my newly fashioned homemade front seat cover onto the lower seat frame and springs. The original 60 year old springs are very worn out and super soft, providing only enough support for maybe a small cat. Identical replacement springs are not available, all generic upholstery springs I've found are way too large in diameter and length. If any human sits on this after the burlap, foam topping and seat cover is installed, they will find their bottom bottomed out, so to speak. I expect the new seat cover and other materials to be quickly damaged as a result.
So I'm stuffing the 36 front seat coils with cotton batting to bolster them a bit. The photos provide a glimpse of the stuffed coil plan. An idea snatched from a youtube video. Seems reasonable. Anybody else done this sort of odd seat spring repair? Does it work? Any better ideas? If so, please comment on the project discussion page.
  • 4 months later...
