Frazbroon Posted September 8, 2017 Share Posted September 8, 2017 Hello I have a 1982 Toyota hiace with a rebuilt 18r engine. I have replaced the fuel filters and all electrical components . Unfortunately it is cutting out when I come to a stop or if coasting . It doesn't cut out any other time. I have just replaced the PCV valve but no luck . Any suggestions welcome Quote Link to comment Share on other sites More sharing options...
tortron Posted September 8, 2017 Share Posted September 8, 2017 Brake booster no good. Leaking vac when you stop and messing up the timing 1 Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted September 9, 2017 Share Posted September 9, 2017 best way to test the booster is to pump the brake pedal a few times with the engine off then hold your foot on the brakes and start the engine. if the booster is working then your foot will sink a bit as the booster applies more brakes. also with the engine at idle quickly push and release the pedal once. if the revs change then there is a leak internally and the booster is naf. To me it sounds like the slow circuit in the carb has a blockage or restriction. probably needs a good clean. 1 Quote Link to comment Share on other sites More sharing options...
Frazbroon Posted September 14, 2017 Author Share Posted September 14, 2017 Okay so vacuum tested and not the problem. Chased down a dirty carb which did help and found that the new condenser I had fitted was faulty . Thanks for the help Quote Link to comment Share on other sites More sharing options...
