Ranter Posted February 14, 2017 Share Posted February 14, 2017 With complete disregard for the diagnoses effort above I'll offer that 3 things usually stop these cars, and your fuel pump is apparently working. Crank angle sensor or timing belt jump due to water pump failure are the main reasons I see them stop, while computer issues are not uncommon its not the first conclusion drawn. Quote Link to comment Share on other sites More sharing options...
spiderwebfx Posted February 14, 2017 Author Share Posted February 14, 2017 3 hours ago, Ranter said: With complete disregard for the diagnoses effort above I'll offer that 3 things usually stop these cars, and your fuel pump is apparently working. Crank angle sensor or timing belt jump due to water pump failure are the main reasons I see them stop, while computer issues are not uncommon its not the first conclusion drawn. Cheers man, I appreciate the input. I've managed to get spark, so i've now eliminated that as well. Guess next step is checking what you've mentioned. Otherwise, I'll call it quits on trying to fix and get her to take it to a mechanic instead. Quote Link to comment Share on other sites More sharing options...
fuel Posted February 14, 2017 Share Posted February 14, 2017 That's a good point - when it does wind over on the starter, does it sound like it has even compression or does it spin a bit faster as if it doesn't have compression? Quote Link to comment Share on other sites More sharing options...
spiderwebfx Posted February 14, 2017 Author Share Posted February 14, 2017 Definitely sounds like it still has compression. I've turned it over with and without spark plugs in and there is a huge difference. Quote Link to comment Share on other sites More sharing options...
fuel Posted February 14, 2017 Share Posted February 14, 2017 I would maybe pull off the upper timing belt cover and just double check the timing marks - other than that it could be the ECU. Quote Link to comment Share on other sites More sharing options...
spiderwebfx Posted February 14, 2017 Author Share Posted February 14, 2017 Ahk, I will check that tomorrow. Quote Link to comment Share on other sites More sharing options...
moon Posted March 25, 2017 Share Posted March 25, 2017 did you rectify this problem?interested to find out as i have a similar pita here Quote Link to comment Share on other sites More sharing options...
spiderwebfx Posted March 29, 2017 Author Share Posted March 29, 2017 Nope. She bought another car. We're now putting it on the market. Quote Link to comment Share on other sites More sharing options...
dabuzz Posted March 30, 2017 Share Posted March 30, 2017 . Quote Link to comment Share on other sites More sharing options...
spiderwebfx Posted March 31, 2017 Author Share Posted March 31, 2017 That was meant to say now putting on the market... Quote Link to comment Share on other sites More sharing options...
