Celica RA45 Posted February 20, 2016 Share Posted February 20, 2016 roman would only pick up about 2 kws as his comp is 2 low to get the benefits ,need 14and above to make power on e85 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted February 21, 2016 Share Posted February 21, 2016 LOL, nope, every engine benefits from e85, Sure you get MORE gains with higher compression ratio, but even with 11:1 you would see 3-5% gain in motor hp. Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted February 22, 2016 Share Posted February 22, 2016 been there done that ,with real results on 11.5 to 1 was better to use bp 98 made 156 kws on std motor .on e85 made 158kws same day same dyno ,but the bp made more through the midrange and uses less fuel ,e85 was 30 % more used over the bp but you are right but for 30%more fuel used i stayed with the bp 1 Quote Link to comment Share on other sites More sharing options...
