uza63 Posted March 6, 2015 Share Posted March 6, 2015 so ive wired it all up, the computers just had a new subboard fitted to run the 3t. ive got the link cable to laptop tune, can any one lend a hand to get this bad boy to fire/ run? running the 2 coils of a 2 channel suby ignitor with the original 4 post distributor signal. any help appreciated. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 6, 2015 Share Posted March 6, 2015 Hmmm I doubt that will work. Needs a sync trigger to run wasted spark. Does it have 2 trigger sensors? Quote Link to comment Share on other sites More sharing options...
downtrail Posted March 7, 2015 Share Posted March 7, 2015 Or a missing tooth at cam speed Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 7, 2015 Share Posted March 7, 2015 Yea 4-1 would be a bit all over the show! Quote Link to comment Share on other sites More sharing options...
uza63 Posted March 8, 2015 Author Share Posted March 8, 2015 Well it works factory and is the only crank positioning sensor on the vehicle Quote Link to comment Share on other sites More sharing options...
uza63 Posted March 8, 2015 Author Share Posted March 8, 2015 And its not wasted spark, its twinspark with 2 distributor chanels Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 8, 2015 Share Posted March 8, 2015 Sorry thought you had ditched the distributor. Should be straightforward. Pull fuel pump fuse then Lock timing in Ecu and adjust dizzi until its matching. Then just try starting it and adjust master until it goes. Then dyno time Quote Link to comment Share on other sites More sharing options...
uza63 Posted March 8, 2015 Author Share Posted March 8, 2015 Lock the ecu timing? Im not sure what to do there, also can i run ignition 1 to both chanels of the ignitor to fire twin coils? Only have the one signal cable Quote Link to comment Share on other sites More sharing options...
downtrail Posted March 8, 2015 Share Posted March 8, 2015 Yes you can run 2 ignitors off one chanel Quote Link to comment Share on other sites More sharing options...
