gx71 rear springs.
mikey205
"bc Cressida mx73" . bolt in rear, weld on front. 1500 bucks from redline performance. they will fit your beast (if I am wrong then someone will pipe up no doubt) .
as for going 40mm low I don't think even adjustable will do that out of the box. 70/80mm is a nice height ,I cant see anyone loving driving on nz roads at 40mm, its a bit on the silly side isn't it ?
they should with keepers and some persuasion. 50-60mm is comfortable, 40mm and below is when its gets tricky.
Sweet thanks for the help. Will look into it some more. Nah 40 or 50 will sweet. Ive got other cars to on long trips for haha
you may also want to check the camber laws and other things. its not easy to cert these things low.
