b1600 drum to disc / drop spindles?
maxted
Hey guys been trying to find some info on putting drop spindles in my b1500, I've got some discs off a b1600 i believe bolt up with changing lower balljoint to a later model one, just wondering if anyone has been through this? or if the drop spindles from later model couriers can be made to work ect? any info is much appreciated, cheers
I did the same went drum to b2000 discs ,
then I had some b2000 stubs modified to flip the bottom balljoint.
the stubs got the bottom taper milled out then a stepped bush with the new taper got pressed in.
it sees the lower a arm sit flat and would remove catseyes with the x member.
those stubs are shelved as the ute wouldn't get out the driveway on them.
make an offer if you want them,
I'm looking at ordering a water to air for the daily so any extra funds would be handy
b1500 is just the same as b1600 drums, yeah I've heard need to use a late model ball joint
Ill pm you regarding stubs jase, roughly what sort of height did it sit at? and was suspension factory otherwise? and what size tyres/rims were you running?
