Celica RA45 Posted April 2, 2014 Share Posted April 2, 2014 discuss and have a laugh Quote Link to comment Share on other sites More sharing options...
Roman Posted April 2, 2014 Share Posted April 2, 2014 Looks good, is there ever much rust to contend with on cars in 'Straya?I'm pretty sure all of the A40 series of cars have dissolved by now in New Zealand haha. Hmmm 2.4 litre beams sounds interesting, starting out with a 5S block? Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 2, 2014 Author Share Posted April 2, 2014 yes 5sfe block 88mm bore and 98mm billet stroke with beams head pistons will be 14.5 to 1 and also a forged rod i can then play with the rotary guys Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 2, 2014 Author Share Posted April 2, 2014 on the rust side it depends on where they are out back nsw just red dirt no rust in melbourne some rust ,but its like any where .most jap cars had rust built into them from about 1980 onwards ,just look at te71 ,fast back corrolla and ma61 supra and ae86 levin .all rust Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 6, 2014 Author Share Posted April 6, 2014 hopefully working on the wiring next ,this should take about a month or 2 as im starting with a new loom and also the m800 motec loom Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted April 6, 2014 Share Posted April 6, 2014 What gear(dog)boxes are you using? Be interesting to see what that 2.4l does! Are there many people running the Honda K24's? Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 6, 2014 Author Share Posted April 6, 2014 its a par dog box, made in sydney. all new guts but overdrive is still synco even thou its straight cut im making 204 kws at the back wheels out of the 2 litre at the moment at 9200 rpm ,be nice to make 260kws at 8200 rpm out of the 2.4 .will most likely need either 52mm quads which will be ok as there is enough meat on my quads to do this ,cams will have the same lift but more duration something in the 260 plus to 270 range at 50 thou range not many people are using the 2.4 honda ,but there are a few using the mazda /ford 2.4 4 cyl 1 at the moment and that is making good power Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 18, 2014 Author Share Posted April 18, 2014 just got back my new2 peice tail shaft that can spin to 11,000 with out destroying any thing ,so happy and making up e85 fuel line and rear brake lines .also going up to bigger rotors and bigger rear calipers to stop it better Quote Link to comment Share on other sites More sharing options...
Roman Posted April 19, 2014 Share Posted April 19, 2014 Hey Glenn, What are you planning on doing with the panhard rod on this one? I remember you saying that on your previous car you have/had an adjustable panhard rod so it raises or lowers the roll centre. Do you make it with different height holes at the 'body' end of the rod? Would be cool to see some photos when you get to this part. Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 19, 2014 Author Share Posted April 19, 2014 you do it on both ends diff and where the panhard rod is bolted 2 ,they have resurfaced the island so the speeds and Gforce is high there was lifting the left going over lukey heights so i put the panhard rod back to std running 230 lbs rear and 350 on the front at the moment and through turn 1 pulling 1.6 g my mate in the sports sedans is pulling 1.8 on slicks through turn 1 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted April 21, 2014 Share Posted April 21, 2014 Holy crap 1.6g! Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 23, 2014 Author Share Posted April 23, 2014 yeah its fast there ,they still have cars crashing going through turn 12 onto the front straight ,my speed there is nearly 190kays now and at the end of the front straight 240 kays at 8800 rpm in 5th most accidents at the island is turn 1. turn 3 coming into honda down from 200 kays to 70 going through hay shed which is straight and then tight right and last going over lukey heights my speed there is nearly 200 going down agear for over the top http://www.piarc.com.au/files/May%202014%20Sprint%20Regs.pdf look at this and will show you the track layout dave Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted April 29, 2014 Author Share Posted April 29, 2014 not happy where shifter comes out will need to take box out and take off extension housing to change shifter posi another 25mm forward should fix this on other news cage is out of white 1 and has been unpicked and trimmed down to go in the red 1 in 2 peices the back half will fit in past the doors and the front just needs a retig and that should finish that Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted May 23, 2014 Author Share Posted May 23, 2014 latest is, motors in ,dry sump tank is in. TRD pipes are in ,rear spoiler is on and shifter housing is in the right place /motor is only in for wiring and the side trims and chrome peices are attached still to do list motec m 800 wiring, new wiring loom for car complete dash assembly to be put in finish off brake tubing and rebleed complete system clutch pedal needs rebleed as well accelerator has turned up from america Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted July 13, 2014 Author Share Posted July 13, 2014 just waiting on dry sump tank from america dry sump pump has arrived waiting on my new race radiator ,then can finish off the new air filter set up waiting on mandrels belt and bracket and pulleys and last waiting on new dry sump pans for rwd and started wiring Quote Link to comment Share on other sites More sharing options...
Styles Posted July 13, 2014 Share Posted July 13, 2014 So love this model of Celica, bugger-all of them in NZ, and none that I know of that are in anything like reasonable condition. Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted July 16, 2014 Author Share Posted July 16, 2014 this 1 was a round head light version and i up dated the front radiator supports and the later panels etc Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted August 3, 2014 Author Share Posted August 3, 2014 ok have done the dry sump set up ,put pics up in the tech section ,just waiting on the rwd sump pans so they can fit into ae86 with beams motors Quote Link to comment Share on other sites More sharing options...
Celica RA45 Posted August 6, 2014 Author Share Posted August 6, 2014 pics of dry sump pan in tech talk Quote Link to comment Share on other sites More sharing options...
Roman Posted August 6, 2014 Share Posted August 6, 2014 So love this model of Celica, bugger-all of them in NZ, and none that I know of that are in anything like reasonable condition. I had one for a little while, impulse purchase from TM a few years back haha. It was the twin round front version though. Hey Glenn, how much oil needs to go in an F series live axle again? Need to fill mine back up once I've put it together again, but I forget. Quote Link to comment Share on other sites More sharing options...
