crooked Posted August 8, 2013 Share Posted August 8, 2013 Hey guys, I'm trying to figure out how I can go about making something a little more than mild, I want adjustable height, anything I can do with camber? Also I want to change the steering box to a rack setup, what would be good to use here? Thanks Quote Link to comment Share on other sites More sharing options...
Callum Radford Posted August 8, 2013 Share Posted August 8, 2013 RT110 Corona? Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted August 9, 2013 Share Posted August 9, 2013 if its the same as my rt84 corona, you can space in the top wishbone (they already have camber adjusting shims to set them up from factory in there) to achieve camber on the front. as for adjustable, why? how often are you going to change, just slam it static low. double wishbone is great for springs as the wishbones never move further apart, so if the spring is captive, its always captive. 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted January 22, 2014 Share Posted January 22, 2014 . Quote Link to comment Share on other sites More sharing options...
dave Posted January 24, 2014 Share Posted January 24, 2014 take out bump stops and just cut springs and they can be slammed with travel and captive Quote Link to comment Share on other sites More sharing options...
Scottymac Posted November 28, 2014 Share Posted November 28, 2014 I am running qa1 adjustables in mine the shortest ones bolt in with an adaptor on top of the shock to fit into the original mounting hole Quote Link to comment Share on other sites More sharing options...
