Ngapuhi rollaz Posted December 7, 2012 Share Posted December 7, 2012 Hi all. I have a 81 sigma that has a 2L carby motor. Headers with a 2.5" mandrel bent full system. Going to get a regrind on the cam but im after some info on the carb. Webber 32/36 is what iv been told to use. Could a 2.6 carb out of a L200? Which would be the most easiest mod or the one that will be the best result? Any help is much appreciated. Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted December 7, 2012 Share Posted December 7, 2012 From what I can gather the carb off the 4G54 is a 32/35. I assume you would have to get it re-jetted to suit the 4G63. This (i believe) would be a bolt on upgrade whereas the Weber would need either an adaptor plate or your inlet manifold modified. Check out Triggers build //oldschool.co.nz/index.php?/topic/23341-triggers-ex-lancer-starmax/page__hl__starmax The Weber carb is a tried and true method where the 2.6 carb may be a gamble. Quote Link to comment Share on other sites More sharing options...
Bantam Posted December 10, 2012 Share Posted December 10, 2012 $80 for a 32/36 off a 2 litre sierra. Quote Link to comment Share on other sites More sharing options...
Ngapuhi rollaz Posted December 11, 2012 Author Share Posted December 11, 2012 In working condition or needing a rebuild? Quote Link to comment Share on other sites More sharing options...
Ogre Posted December 12, 2012 Share Posted December 12, 2012 Go with the weber x10. I dont even think the 2.6 is a "bolt on" anyway. They are just as shit as the standard one and i doubt you would notice any benifit whats so ever apart from increased fuel consumption. You can get an adapter plate to use with the weber. trigger did it the hard way coz thats how he rolls. Quote Link to comment Share on other sites More sharing options...
Ngapuhi rollaz Posted December 12, 2012 Author Share Posted December 12, 2012 Lol. Yea im not down for the hard way. Easy is the way to go. Easy but making sure it still works and works well. Webber itis. Quote Link to comment Share on other sites More sharing options...
Bantam Posted December 13, 2012 Share Posted December 13, 2012 Weber is good. Just needs main gasket about $10 on TM Quote Link to comment Share on other sites More sharing options...
Ngapuhi rollaz Posted December 13, 2012 Author Share Posted December 13, 2012 Yea keen as. Heas my number. 02102434872 Quote Link to comment Share on other sites More sharing options...
