Using a random oil filter ok?
cute wee gem
So the standard Piazza oil filter (RZ142A) hits the steering rack in the gem, so I found a random filter laying about (probably from a toyota?) which is heaps skinnier (Z411 I think it was)
It screws in fine and the seal still fits on the housing ok, so will it be fine to use? I can't see why not, but figured I'd ask to make sure I'm not overlooking something.
yeah Z411 and Z142A are common Mitsubishi filters. You could try a Z79X as well which is about as short as a Z142A but not as wide/chode like. If the thread and the sealing o-ring the seal, then I see no problem switching filters. Some filters just have more filtering material than others.
