KKtrips Posted March 29, 2012 Share Posted March 29, 2012 I went to Pinkys at lunchtime and have studs and verniers with me - they are 14mm on the knurl and 41 mm long from under the head to the end of the thread (46mm overall) What time you coming through the station and I'll do a handover.. Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 29, 2012 Author Share Posted March 29, 2012 hmmm might be marginally too short...sound similar to the ones from the rear that I tried, still worth a shot though, and def keen to borrow verniers will be at at station about 520.... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 29, 2012 Share Posted March 29, 2012 Choice - will see you then. Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 29, 2012 Author Share Posted March 29, 2012 sweet. appreciate it man. Quote Link to comment Share on other sites More sharing options...
MoparOrNoCar Posted March 29, 2012 Share Posted March 29, 2012 Easiest way to install a wheel stud, brother: Line it up in the hole with a Square, give it a tap with an hammer to locate it, then put a wheel nut on and wind it in, use a bigger nut as a spacer if the knurled bit comes through the hole. Heating the facing plate (Gas torch or inthe oven) helps but dont heat the stud, it buggers the case hardening. Cheers Quote Link to comment Share on other sites More sharing options...
