Seedy Al Posted December 22, 2011 Share Posted December 22, 2011 Hey guys, So i have a 2jz here in my shed, and I'm wanting to go manual. I'm not talking turbo or anything, so whats the cheapest way to manualise this whore. I assume adpater plate, which is easy enough to buy, what is there a flywheel off another motor like a 3sgte or something that I can use? And if so, what clutch etc would you suggest? Cheers guys, looking into this for next years first car project. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted December 23, 2011 Share Posted December 23, 2011 Make all your own shit, otherwise it's fucking expensive. Use the cheaper W series box rather than R series Maybe cut and shut an auto bellhousing if you can weld ally or know someone that can do it cheap. I did a fair bit of research when doing my conversion and didn't come across anyone re-drilling flywheels from another series. If you can find a 5 speed jza80 being wrecked, you could probably get the whole lot cheaper I'd imagine. (easiest option, but might take ages to find one) I did mine the expensive way due to the car being my daily/impatientness 650ish for new bellhousing 550ish for new exedy sport clutch kit 400ish for new CNC flywheel W55 for 400ish You could do it for under half of that if you have plenty of time to find cheap bits and can make stuff yourself. JZ shit ain't cheap Maybe of interest? http://www.trademe.co.nz/motors/car-par ... 767296.htm Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted December 23, 2011 Share Posted December 23, 2011 Also, what car is it going into? Quote Link to comment Share on other sites More sharing options...
R100 Posted December 23, 2011 Share Posted December 23, 2011 I put a G52 box (w series bolt pattern) behind my 2JZ Got a new bellhousing from toyota, aftermarket flywheel $300 ish and clutch kit from repco $250 ish. Still cost a good part of $1000 also bought a set of manual flywheel bolts from nzperformance for a 4AGE Quote Link to comment Share on other sites More sharing options...
