swagg'n sam Posted October 28, 2011 Share Posted October 28, 2011 dose any 1 know if these kw bucket seats will go in my dx without having to cert any thing or make frames http://www.trademe.co.nz/motors/car-parts-accessories/interior/seats/auction-418726236.htm Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 28, 2011 Share Posted October 28, 2011 None of the aftermarket seats will bolt straight on to your car with out the bolt on subframes or mounts Easy enough to redrill your rails or use strap steel to make mounts. Quote Link to comment Share on other sites More sharing options...
swagg'n sam Posted October 28, 2011 Author Share Posted October 28, 2011 would it pass wof like that though ?? Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 28, 2011 Share Posted October 28, 2011 Mine used too, but obviously it depends on the person doing your WOF test. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 28, 2011 Share Posted October 28, 2011 ive done a few seat installs, used decent angle or flat steel and kept it tidy, and sprayed it black to match. never even noticed Quote Link to comment Share on other sites More sharing options...
Shandangles Posted October 29, 2011 Share Posted October 29, 2011 ive done a few seat installs, used decent angle or flat steel and kept it tidy, and sprayed it black to match. never even noticed This, or im pretty sure KW do bolt in rails for ae86, which will be the same as a ke70, then def will have no issues Quote Link to comment Share on other sites More sharing options...
ke70_83_dx Posted October 29, 2011 Share Posted October 29, 2011 im pretty sure KW do bolt in rails for ae86, which will be the same as a ke70, then def will have no issues Apparently ae86 rails don't bolt up perfectly- Two line up, one's very close, the other one's around ten mm off. Quote Link to comment Share on other sites More sharing options...
